Grounding after fiberglass tub install - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Grounding after fiberglass tub install
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-23-2014, 08:43 PM   #1
danfrye
1978 CJ7
Transferring everything to a new frame and had to purchase a fiberglass tub due to rust. Anyway, using the old wiring harness for under the dash and to the rear lights. Have everything plugged back in but there is obviously a ground problem. I'm using the old steal dashboard.
I'm wondering if it can be fixed by installing a ground from the main fuse box/wiring harness, plug assembly at the firewall, under the dash. I'm hoping I don't have to specifically ground every individual thing.
Thanks for any tips you can send my way
Dan
1978 CJ7 build
danfrye is offline   Reply With Quote Quick reply to this message
Unread 08-23-2014, 10:09 PM   #2
jammer1
1979 CJ7
Run the ground directly from the battery. I put a junction block on the side of the tub under the dash. Two grounds from the battery, one directly to the dash, the other to the junction block. Any additional grounds I need can be connected to the junction block. Once you have the dash grounded, anything touching the dash that would normally use the dash for a ground should be grounded. Make sure the gauges and lights have a good ground. I've heard that you can burn out the gauges if they don't have a good ground. For the rear lights I drilled and tapped a hole in the frame and installed a bolt. From this I ran the grounds. Make sure you use a thick gauge wire from the battery to the dash and also to the junction block.
jammer1 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2014, 12:39 AM   #3
hutch1200
hutch1200's Avatar
1979 CJ7
That's 100% the way I did it. Glass tub, steel dash, glass nose.
http://www.grainger.com/product/QUIC...AS01?$smthumb$
http://www.bizrate.com/belden-sc13b1...026832401/shop
All "long term borrowed" from Verizon truck. These all come in different lengths
Don't forget a Buss Bar on the cowl. http://www.delcity.net/store/Stud!Ty...Blocks/p_73275 Try to find one w/an enclosed lid.
Good luck
The only "FINISHED CJ" is the stripped one in a junkyard w/a bent frame.
hutch1200 is offline   Reply With Quote Quick reply to this message
Unread 08-24-2014, 05:26 AM   #4
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Don't forget all the light fixtures need a ground to their cases for the signals to work. The ground that is there is only for the running lights. I originally ran an extra wire in each loom piece to pick these up, but now have a Centech harness that came with the extra ground wires. My wiper motor also didn't much like using the hinges for a ground so I ran a dedicated one to one of its mounting bolts.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 08-24-2014, 04:41 PM   #5
danfrye
1978 CJ7
Okay... Besides running a wire from the ground of battery directly to the steal dash, you put in a ground junction box under the dash too? That's something that has multiple screw in points to run ground wires under the dash as needed... Right?
Unread 08-24-2014, 04:54 PM   #6
jammer1
1979 CJ7
Correct, as you add on to the jeep, you now have a good ground to run to. I forgot to mention I also ran one to the drivers side fender for future projects. This is a kit, I made my own up (cheaper and more heavy duty). But this gives you the idea http://www.painlesswiring.com/webcat...v.php?sl=40026
Unread 08-24-2014, 10:13 PM   #7
danfrye
1978 CJ7
Got it. Makes total sense now. Really appreciate the help.
