Groaning Noise From Rear Wheel - JeepForum.com
post #1 of 11 Old 10-03-2013, 10:23 AM Thread Starter
allanbranch
1978 CJ5
I'm having a groaning noise coming from my rear driver's side wheel. It happens when I start from a stop and especially when turning left.
See this video, it happens at :10 and :14
http://www.youtube.com/watch?v=jNF65...ature=youtu.be
Thoughts?
FYI: I'm going to ask many stupid questions. I write software for a living, engines and Jeeps are a new technology to me. Go easy on me.
Last edited by allanbranch; 10-03-2013 at 10:24 AM. Reason: youtube link didn't work.
allanbranch is offline
post #2 of 11 Old 10-03-2013, 01:21 PM
LumpyGrits
Axle bearing say'n, bye-bye, me thinks.
Do you have oil leaking on the inside sidewall of your tire?
When was the last time you checked your rear hub nut for torque(250ft/lbs min.)?
Check your diff oil level.
Way to much background noise to be sure with my bad ears.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is online now
post #3 of 11 Old 10-04-2013, 09:04 AM Thread Starter
allanbranch
1978 CJ5
LumpyGrits, thanks for the feedback.
My wife shot another video. Youtube jacked up the videos and make them all warped looking.
No oil leaks on the side of the tire, what would that indicate axle issue?
post #4 of 11 Old 10-04-2013, 10:25 AM
jeepwhore
So it only makes the sound for a second after you start moving? It almost sounds like the brake shoes are binding up inside the drum. Hard to tell though as the engine noise drowns out alot of the actual sound. If a wheel bearing was that far gone to make a sound like that I would think it would be heard all the time. Pull your drums off and make sure all the brake hardware is still in place and that the shoes haven't fallen apart in there. It could very well be a bearing but again, it's hard to really hear the sound.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #5 of 11 Old 10-04-2013, 10:34 AM
LumpyGrits
X2 on pull'n the drums.
If you don't see anything there.
Pull the diff cover off and look for broken gear teeth.
I would stop driving it till you get this fixed.
LG
post #6 of 11 Old 10-04-2013, 10:42 AM Thread Starter
allanbranch
1978 CJ5
You gentlemen are very much appreciated. Many thanks, have a great weekend.
post #7 of 11 Old 10-04-2013, 10:49 AM
LumpyGrits
Let us know, what you find
LG
post #8 of 11 Old 10-26-2013, 01:36 PM Thread Starter
allanbranch
1978 CJ5
Well the wheel bearing looks fine, the u-joints had some wiggle room so we swapped those out. That wasn't it, then we spotted a rotten spring perch. That's the next thing we'll change out. I'll replace both while I'm at it.
post #9 of 11 Old 11-12-2013, 06:16 PM Thread Starter
allanbranch
1978 CJ5
Well the spring perches are replaced and nope that's not it either.
I created a new thread because I think I found the problem, or I found another problem.
http://www.jeepforum.com/forum/f19/h.../#post17653281
post #10 of 11 Old 11-13-2013, 06:20 AM
southshore30
1982 CJ7
Groan more turning one direction more than the other? Probably time for wheel bearings. If you don't have one piece axles then do them at the same tome
Firefighters Jeep Club
SBC350,T-176,D-300,D44
southshore30 is offline
post #11 of 11 Old 11-13-2013, 07:58 AM Thread Starter
allanbranch
1978 CJ5
Turns out the woodruff key was broken, I'm putting in one piece axles now. Thanks!
