Grinding when the wheel is fully turned left/right - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Grinding when the wheel is fully turned left/right
Build your Dream Jeep with Poison Spyder's Interactive GarIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffStuff Memorial Day Sale!
Unread 01-16-2011, 07:29 PM   #1
KJNewbs
1983 CJ7
Hey everyone...
I'm looking for some suggestions on where to start finding a problem. When I turn the wheel all the way left or right, there is some grinding and it almost feels like it is going to stall the Jeep. I also feel like I hear whooshing sound in the steering column (probably not the best explanation).
I just had a new steering gear box and power steering pump installed, but I honestly can't recall if the same problem existed before hand (The Jeep pulled really bad to the right when I first got it so the gear box was one of the first things I had done and I'm finally now getting to really drive it and.
If the problem is gear box or pump related, I'll fight the shop that installed it to make it right - I just want to be educated when I call them first.
Thanks all...
-KJ Newbs / Jersey
1983 lime green CJ7 - 258 with DUI & Weber, Crane cam, 2" lift, MTs w/ BFGs
2010 2-Door, 6-Speed Black JK Sahara - Teraflex 3" Coil Lift with Front Lower and Rear Upper Flex Arms - Bilstein 5100 Shocks -JKS Front Adjustable Track Bar - Teraflex Front Knuckle Gussets - Rock Hard Oil Pan/Engine Skid - Rock Hard Transfer case skid - Rock Hard Evap relocation Kit - Poison Spyder Rocker Knockers - MBRP off-road exhaust - AEV Pintler Wheels - GoodYear MTR/K 35x12.5x17 - Detroit Track Loc Carrier up Front - Yukon 4.88 Gears - Cobra 75 CB with Cool Tech bracket - Die-Tech mirror relocation brackets
KJNewbs is offline   Reply With Quote
Unread 01-16-2011, 07:51 PM   #2
LT1CJ7
1983 CJ7
Hard to tell, But sounds like the new pump is part of the problem.
Just take it back and have them look at it.
LT1CJ7 is offline   Reply With Quote
Unread 01-16-2011, 08:10 PM   #3
baldfatdad
Check the power steering fluid. Turn the wheel lock to lock a couple times then check it again. Could be air in the system. Some times its hard to get it out.
If its full take it back, could be bad box or pump.
baldfatdad is offline   Reply With Quote
Unread 01-17-2011, 04:58 AM   #4
KJNewbs
1983 CJ7
Thanks. I'll check the fluid after work today.
-KJ Newbs / Jersey
Unread 01-17-2011, 01:30 PM   #5
Fatman
2008 CJ7
just throwing this out there. no idea what the sound is like and cant see. (obviously) the new gear box might have a lil bit more throw left and right than the old one. this can cause one of two conditions, if not both. look for tire rub in full turn, and also check for U joint bind. check this and adjust stops if you detect interference.
Fatman is offline   Reply With Quote
Unread 01-17-2011, 06:20 PM   #6
KJNewbs
1983 CJ7
Fat man...(sounds wrong calling you that), what do you mean adjust the stops?
-KJ Newbs / Jersey
Unread 01-17-2011, 06:42 PM   #7
nshefbuch
1982 CJ7
if thats a pic of your jeep your tires are to wide. you need wheel spacers. adjusting the stops prolly wont help with that. my buddy had the same problem on his running 35 x 15.5 claws. he added 2" wheel spacers and it cleared but barely. to adjust the stops there is a bolt that stops the knuckle from turning so far. basically adjusting those will decrease your turning radius. you will need to invest in some spacers.
82cj7 / soa wrangler springs / amc 360 / t18a granny / d300 twin stick / 37" pitbull rockers radials / h1's / 3/4ton d44 with high steering / 14 bolt ff / clocking ring
nshefbuch is offline   Reply With Quote
Unread 01-17-2011, 06:46 PM   #8
KJNewbs
1983 CJ7
I didn't notice anything rubbing when I turned the wheel....but you could be right. I'm running 33s with a 1.5" body lift and 2" spring lift, but no spacers. I guess there is no way to prove that's the problem without putting them in and seeing if anything changes?
-KJ Newbs / Jersey
Unread 01-18-2011, 10:28 AM   #9
nshefbuch
1982 CJ7
its not t diamater that matters it will be how wide the tires are. my friend's jeep came with 31 sx tires but they were very wide. i would think anything wider than 12.5 would rub but just my guess. look at your leaf springs and see if there are marks from the tire rubbing.
Unread 01-18-2011, 11:15 AM   #10
gojeepin
gojeepin's Avatar
1983 CJ7
Both measurements matter. The taller tire will go deeper in the well area when turned... and you already explained the issue with width.
My 35X1250s will rub if I lift a wheel while turning. It makes quite a grinding noise.
Vibration? Bump steer? Wandering? Read: Steering, suspension, and driveline basics. An article on how it works and where to look for problems.
83 CJ7, 4.1L 6cyl (4.0L bored .030" over), 35" tires, T-5 transmission, Dana 300 TC, Trussed AMC 20.
gojeepin is offline   Reply With Quote
