Grinding noise while starting. Help Please. - JeepForum.com
post #1 of 7 Old 06-14-2009, 04:58 PM Thread Starter
sundownbrown
The other day we fixed an oil pan leak on my jeep. To get to all the bolts we had to take out the starter. Once we got the oil leak fixed we put the starter back in. We started the jeep and had a huge grindind noise coming from the flywheel and bell housing. The jeep still starts but, what do you think is causing the noise? Thanks
sundownbrown is offline
post #2 of 7 Old 06-14-2009, 05:25 PM
FLBOY
Certanily grinding between the starter and flywheel . Is ,or were there shims in the starter mounting bolts ?
It,s better to be stuck , Than to have chickened out and went home
FLBOY is offline
post #3 of 7 Old 06-14-2009, 06:04 PM
bigjoe
1977 CJ7
Sounds like a shim issue. 2x's did you have any shims?
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #4 of 7 Old 06-14-2009, 06:27 PM Thread Starter
sundownbrown
There were no shims. It looks like on the starter that the flywheel teeth are not getting a good bite. Maybe when we put the pan back on something got binded in there maybe. What do yall think?
post #5 of 7 Old 06-14-2009, 07:31 PM
thantos858
1974 CJ5
Are the teeth broken on either?
thantos858 is offline
post #6 of 7 Old 06-14-2009, 08:19 PM
papaj
1979 CJ5
Double check the mounting of the starter to the housing that it is straight.
The engine stops mostly at three locations equally as seen on this pic which the chalk marks show where the worn teeth are, so you may need to rotate the flywheel to see bad teeth. The flywheel can be spun to gain a better bite but if it's removed, it's better to replace it.
papaj is offline
post #7 of 7 Old 06-14-2009, 09:55 PM Thread Starter
sundownbrown
The flywheel looks fine and there are no broken teeth. We are going to count the teeth tomorrow and replace it if it is not the right one.
need help with grinding noise jefflacy Jeep CJ Forum 6 02-02-2010 10:28 PM
Starter Problem - grinding noise TKFireman Jeep CJ Forum 4 05-10-2009 07:35 PM
Grinding Noise in reverse CompGuru Jeep CJ Forum 19 10-31-2007 09:39 PM
grinding noise 83 cj-7 258 Jeep CJ Forum 11 01-03-2005 07:22 AM
grinding noise jeepster18_88 Jeep CJ Forum 1 02-27-2002 02:59 PM
