Grinding noise question - JeepForum.com
post #1 of 4 Old 10-01-2010, 07:15 AM Thread Starter
kward
Every once and awhile when I start my jeep with the clutch pushed in I get a loud spinning/grinding noise that goes away when I let the clutch out or after about 5 seconds. Is this my throwout bearing? When I decide to drop the trans and take a look what parts should I change for the simple fact that I already have the trans out of the jeep so I not going back in 2 years later? Thanks for the help everyone!!!
kward is offline
post #2 of 4 Old 10-01-2010, 08:13 AM
Hybrid Jeep
1976 CJ5
I would bet this is your pilot bushing actually... could be your throwout bearing.. but really sounds like the pilot bushing.
When you drop the trans.. I, personally, would take off the clutch and flywheel.. have the flywheel machined, get a new clutch (I used LUK), get new pilot bushing, get new throwout bearing.
Couldn't hurt to drain the trans.. pop the cover and look around.
That should make you good to go man!
Hybrid Jeep is offline
post #3 of 4 Old 10-01-2010, 08:29 AM
gojeepin
1983 CJ7
I tend to agree with the previous post. It could be either the throwout bearing or the pilot bearing/bushing.
If it goes away after you let the clutch out or after about 5 seconds with the clutch pedal depressed, I'd tend to look at the pilot bearing/bushing...
because, if it was a throwout bearing problem, it normally would keep doing it as long as the clutch pedal was depressed.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #4 of 4 Old 10-01-2010, 11:24 AM
brandon20
just went threw it. thats the throwout bearing. when pulling tranny i replaced throwout bearing,disk,pressure plate,pilot bushing,clutch fork,fly wheel and the whole manual linkage system i also replaced the rear main seal and oil pump and pan,
brandon20 is offline
need help with grinding noise jefflacy Jeep CJ Forum 6 02-02-2010 10:28 PM
Grinding noise while starting. Help Please. sundownbrown Jeep CJ Forum 6 06-14-2009 09:55 PM
Grinding Noise in reverse CompGuru Jeep CJ Forum 19 10-31-2007 09:39 PM
grinding noise 83 cj-7 258 Jeep CJ Forum 11 01-03-2005 07:22 AM
grinding noise jeepster18_88 Jeep CJ Forum 1 02-27-2002 02:59 PM
