grinding noise - JeepForum.com
post #1 of 12 Old 12-31-2004, 11:26 PM Thread Starter
83 cj-7 258
83 cj-7 258's Avatar
grinding noise
When im going between 5-20 mph i hear a gringing noise coming from the drivetrain. My 1st thought that the tc was in the 4wd, but it was not. Then I checked the hubs , they were also in the 2wd position . I know the throw out bearind is shot, so could the noise be coming from the piolt bearing.
THANKS!
83 cj-7 built Chevy 350, sm420, dana 300. Superlift 4in lift, 33x12.50 mikey thompson mtz.
83 cj-7 258 is offline
post #2 of 12 Old 01-01-2005, 07:33 AM
CJ51973
CJ51973's Avatar
Neither your pilot bushing or your throw out bearing should be engage while driving at 5-20 mph. It could be any number of things including your transmission &/or t'case. Does it do it when you are in different gears/going faster? Does it do it on acceleration/decelleration? Louder on acceleration/deceleration? Is the noise louder/quieter with the clutch in?
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #3 of 12 Old 01-01-2005, 10:46 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Does it do it in all gears, or only in first? Does it change if you ride the cluch pedal? Does it change under acceleration? Deacceleration? Might also check front wheel bearings and disc brake pads and backing plates.
jeepdaddy2000 is offline
post #4 of 12 Old 01-01-2005, 11:50 AM
caseypotts
1980 CJ7
grinding noise
Sounds like it is time for some new U joints.
caseypotts is offline
post #5 of 12 Old 01-01-2005, 11:37 PM Thread Starter
83 cj-7 258
It only does it in 1st gear and it does not get louder. Its the same under acceleration and deacceleration. Once i put the clutch in the noise stops. It doesn't always grinds. It sounds like it is coming from the clutch area or the front driveshaft. I dont think its the brakes because it sounds like its coming from the center of the jeep.
THANKS!
post #6 of 12 Old 01-02-2005, 06:18 AM
jadams68
jadams68's Avatar
Unscrew the transmission cover and look inside for chipped teeth or a bad 1st gear synchro. Drive it around slowly with the cover off to see if you can identify the noise better.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #7 of 12 Old 01-02-2005, 07:08 AM
CJ51973
CJ51973's Avatar
CJ51973 is offline
post #8 of 12 Old 01-02-2005, 10:28 AM
jeepdaddy2000
1971 CJ5
The fact that it only does it in first indicates a trans problem. You need to pull the shift cover and take a look. You need to inspect the shift forks for wear, bending. Make sure the forks haven't sheared the roll pins connecting them to the rails. Be sure there isn't damage to the reverse shift mechenism causing the reverse idler gear to come in contact with the first gear. Put the lide on,shift into first, then carefully remove the lid and inspect the gear mesh. Again, be sure to look at the reverse idler. Problems other than shifting are bad countershaft bearings/thrust washers,bad output bearing, worn first gear thrust washer.
post #9 of 12 Old 01-02-2005, 11:50 AM Thread Starter
83 cj-7 258
sometimes when i put it in to reverse it grinds, you can hear and feel it. this is only at a stop when going into reverse. now I remenber a few days ago i was at a stop light, light turned green jeep stalled out of no where. Fired it back up hopped on the gas ans heard a very bag grinding noise. stopped at a gas station ever thing locked fine , so i headed home with coution. Would this have to do with grinding noise, even though the noise was there before the inncident.
THANKS!
post #10 of 12 Old 01-02-2005, 04:21 PM Thread Starter
83 cj-7 258
i finally found the problem. Its when i have my foot resting on the clutch, and the reason i dont hear it in any other gears is because the jeep gets to loud to hear it. I know my throw out bearing is shot because when im netural it rattles like crazy. Can I replace the throw out bearing without removing the trans.
THANKS!
post #11 of 12 Old 01-02-2005, 06:19 PM
jadams68
jadams68's Avatar
You sure can... remove the engine... DOH!
THANKS!
jadams68 is offline
post #12 of 12 Old 01-03-2005, 07:22 AM
CJ51973
CJ51973's Avatar
You have to separate the engine from the transmission. Personally, I would pull the transmission and tranfercase out and leave the engine in. Some people go the other way. While I had it apart I would pull the transmission cover and give everything a good look see. It would also be a good time to repair any leaks.
CJ51973 is offline
need help with grinding noise jefflacy Jeep CJ Forum 6 02-02-2010 10:28 PM
Grinding noise while starting. Help Please. sundownbrown Jeep CJ Forum 6 06-14-2009 09:55 PM
Starter Problem - grinding noise TKFireman Jeep CJ Forum 4 05-10-2009 07:35 PM
Grinding Noise in reverse CompGuru Jeep CJ Forum 19 10-31-2007 09:39 PM
grinding noise jeepster18_88 Jeep CJ Forum 1 02-27-2002 02:59 PM
