Green Stuff in the passenger floor pan (antifreeze)? - JeepForum.com
post #1 of 9 Old 02-03-2009, 05:16 PM Thread Starter
hookntail
1979 CJ7
I got in the Jeep yesterday after it had been sitting for several days and there was a small puddle of what looked to be antifreeze in the passenger floor board. Im thinking that may be coming from some part of the heater. Am I correct in assuming this? Have any of you ever experienced this?
A good day at work never beats a day (or night)working on the Jeep...
1979 CJ7; 360 w/t 3 speed; 33 ProComp M/T/s; and sounds sooo good!!!!!
hookntail is offline
post #2 of 9 Old 02-03-2009, 05:22 PM
madawaska
1975 J-Series Truck
I think your heater core is leaking!
madawaska is offline
post #3 of 9 Old 02-03-2009, 05:24 PM
bigjoe
1977 CJ7
Ahhh just put some of it on your fingers and give a lick to see what it is....
All joking aside it sounds like you have either a heat core hose clamp that is loose or a hole in the heater core itself. The core is located up under the dash. Check the clamps first. If they are tight you'll need to repair/replace the core. Goodluck.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #4 of 9 Old 02-03-2009, 05:36 PM
Born2Ride
1980 CJ7
I actually have that same exact problem on my 80' cj7..It might be there one day and then go a month and not leak so Im not gonna worry about it til it gets worse...
Be safe,have fun!
Born2Ride is offline
post #5 of 9 Old 02-03-2009, 06:22 PM
JIBTEXHNKA
1987 YJ Wrangler
same here, then i realized it stopped because there was nothing left to leak anymore
JIBTEXHNKA is offline
post #6 of 9 Old 02-03-2009, 06:36 PM
CJhollic
1980 CJ7
BAd heater core most likely
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #7 of 9 Old 02-03-2009, 11:04 PM
479AZ
1978 CJ7
The clamps are under the hood, most likely the core is leaking. Not too expensive to replace but you have to open up the dash to get access to everything.
479AZ is offline
post #8 of 9 Old 02-03-2009, 11:06 PM
cmvash
1973 CJ5
One of the brass nipples is probably loose. Just bar-leak it
cmvash is offline
post #9 of 9 Old 02-04-2009, 02:37 AM
powermacj7
That is exactly what was happen to mine. The Brass feed started to separate from the unit, and I was getting anti-freeze as you are. You have to replace the heater-core, or eliminate the heater for now!!!
powermacj7 is offline
Antifreeze on floor sakisaki400 Jeep CJ Forum 9 07-12-2010 09:21 PM
how much antifreeze? 50/50? shok47 Jeep CJ Forum 5 10-13-2009 06:27 AM
Antifreeze Everywhere Big Block Jeep CJ Forum 6 01-26-2009 06:41 PM
Antifreeze on the passenger side floor DT5150 Jeep CJ Forum 8 11-24-2008 09:51 AM
Antifreeze in the oil Jeepdude84 Jeep CJ Forum 9 09-29-2008 04:28 PM
