Great Day! Got my CJ7 to start. Now I have a tach wiring question - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Great Day! Got my CJ7 to start. Now I have a tach wiring question
Introducing MONSTALINERô UV Permanent DIY Roll On Bed LineORS Recovery RopeSynthetic Winch Rope from ORS
Unread 08-27-2014, 06:11 PM   #1
TnKanRick
1983 CJ7
I recently did a dash rehab / reinstallation and couldn't get my Jeep to start after the reinstall. I added an aftermarket Crown tach to the dash. The instructions for the Crown tach said not to use the factory tach wiring. So, I removed the factory tach wire going to the distributor side of the coil and hooked the Crown tach to the distributor side of the coil.
I've spent the last few days trying to figure out why the Jeep would no longer start and it turns out that removing the factory tach wire from the coil was the reason. Once I hooked the factory tach wire back up to the coil the Jeep started right up. So now I have a quandary. Do I hook both the Crown tach wire and the factory tach wire to the coil. I'm sorta afraid if I do it will fry my Crown tach.
Anybody know for sure?
The great thing about experience is that it allows you to recognize the same mistake every time you make it.
TnKanRick is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 06:31 PM   #2
LumpyGrits
What's wrong with the OEM Tach?
Much better than Crown--
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 06:39 PM   #3
OrangeCJ-5
OrangeCJ-5's Avatar
1978 CJ5
Sounds to me like he never had one which is why he 'added an aftermarket Crown tach to the dash.'
OrangeCJ-5 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 06:43 PM   #4
LumpyGrits
That is possible-
LG
Unread 08-27-2014, 07:03 PM   #5
keith460
Jeep. There's Only One
keith460's Avatar
Factory tachometer never hooked up to the coil, it is in "series" with the ignition wiring. A wire plug gets pulled apart under the dash to connect the factory tach.
A crown tachometer connects as like any other aftermarket tachometer does. 12V+, Grd and Coil tach (-) for signal which is green. Plus another wire for dash lighting which I believe is white in color.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 07:19 PM   #6
TnKanRick
1983 CJ7
Yes, my Jeep did not have a factory tach but nonetheless has the factory wiring for a tach. Should I attach both the factory tach green wire and the Crown tach green wire to the (-) side of the coil?
Unread 08-27-2014, 09:14 PM   #7
keith460
keith460's Avatar
Mmm, not sure what you mean? There is no green wire for a factory tachometer to connect to the coil.
Are you planning on using two tachometers? One factory and one aftermarket.
Back of factory tach pictured, no green wire. Just red w/tracer and an orange that connect to factory ignition plug under dash and a black and orange for lighting.
1984 CJ-7 Renegade
Unread 08-27-2014, 09:21 PM   #8
Requiem4aCJ
the only factory wire connected to the (-) post of the coil is the wire from the ignition module that tells the coil when to fire, if you disconnect this the engine doesn't run. So yes leave it connected and attach the wire for your new tach with it.
Requiem4aCJ is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 09:44 PM   #9
CSP
That part of the instructions about removing the factory tach is only applicable if you had a factory tach to begin with. No factory tach = no tach wire at the coil, but there are other wires as already noted.
CSP is offline   Reply With Quote Quick reply to this message
Unread 08-27-2014, 10:19 PM   #10
ThisGuyUKnow
The crown tach hooks up to the negative side of your coil. I believe it's the green wire. I bought one to use with my 4.0 swap and it didn't work initially, I had to set the back to 4cyl to get it to work. I'm not sure if that is the same for the 258 set up.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline   Reply With Quote Quick reply to this message
Unread 08-28-2014, 08:05 AM   #11
TnKanRick
1983 CJ7
Thanks guys. That all makes sense now. I made the assumption (yes... rarely a good idea) that the "tach side of the coil" meant that the only thing that could possibly be attached to that side were tach related wires. As Homer Simpson would say.... "DOOH!" I'm seriously red-green colorblind which makes working on wiring that much more of a challenge.... especially in low or artificial light conditions. Thanks again for all the help and replies.
Unread 10-14-2014, 10:56 PM   #12
mapesful
I recently bought a 85 CJ7 and the previous owner removed the dash and all the gauges completely. Would the tachometer cause my jeep not to start?
mapesful is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 06:28 PM   #13
jjgrow
Dumb question, but where do we connect this white tach illumination wire? I've installed an OEM-style tach and just need to connect to the dash light circuit.
- Jeff
1986 CJ-7
jjgrow is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 06:53 PM   #14
John Strenk
John Strenk's Avatar
1976 CJ5
I believe it went into the fuse box originally.
There is a plug called CLK with a little arrow, left side next to the 10 amp ACC fuse.
John Strenk is offline   Reply With Quote Quick reply to this message
Unread 02-19-2015, 06:54 PM   #15
John Strenk
1976 CJ5
If it had a factory tach then yes, Just unpluging it would prevent the engine from running
