greasing throwout bearing - JeepForum.com
post #1 of 14 Old 02-20-2010, 10:45 PM Thread Starter
dangjeep
How do you get to the grease fitting on the throwout bearing ? Do you need to pull the fork out to access ? I have looked inside, but can't see it. My bearing is starting to make noise and I would like to get it to settle down. Everything looked real good when I had the motor out a while ago, now I wish I had gotten a full clutch kit when it was apart.....
dang
dang
84 CJ7-258-T5-D300-4.10 gears 33" tires Nutter Bypassed Team Rushed
dangjeep is offline
post #2 of 14 Old 02-21-2010, 05:18 AM
Mike Romain
Next time you take the motor out you can replace it with a new sealed and packed bearing. There is no servicing of an installed one.
Mike
Mike Romain is offline
post #3 of 14 Old 02-21-2010, 06:11 AM Thread Starter
dangjeep
Thanks Mike, but I didn't want to pull the motor again. I finally have a good running motor. I guess this time I will drop the transmission. I will get a full kit this time......
dang
dangjeep is offline
post #4 of 14 Old 02-21-2010, 06:40 AM
mastercraftka
mastercraftka's Avatar
Ya you dont need to pull the engine, just the tranny and they are sealed no grease fittings on them.
mastercraftka is offline
post #5 of 14 Old 02-21-2010, 07:03 AM Thread Starter
dangjeep
My throwout bearing did have a grease fitting... maybe it was a cheap brand. Before I put it back together, I tried to buy just the bearing since the disc and plate looked real clean. No one locally sold just the bearing, you had to buy the whole kit. At the time I couldn't afford it, so I made due.
dang
dangjeep is offline
post #6 of 14 Old 02-21-2010, 07:52 AM
MontanaCJ5
1974 CJ5
My throwout bearing has a grease fitting also. When I installed it, I faced the fitting straight down and drilled a small hole directly below it through the bell housing. I actually can grease it in the vehicle. The small hole in the bell housing can be filled with a small plug.
MontanaCJ5 is offline
post #7 of 14 Old 02-21-2010, 08:16 AM
mastercraftka
Really that is new to me, learn something new every day.
post #8 of 14 Old 02-21-2010, 12:10 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Is there any access openings on the 3 spds to look in to see if I have a fitting? That'd be great if it does.. I only thought they did that on heavy trucks.
Rick
Cutlass327 is offline
post #9 of 14 Old 02-21-2010, 12:17 PM
Mike Romain
That is a new concept for me also. I would sure try to get at it through the shift fork boot if I could....
Do you remember which way it was pointing when you put it together? You can get hard lines for grease guns so could even shoot a 90 deg off fitting likely.
Mike
post #10 of 14 Old 02-21-2010, 03:08 PM
jeepmaster03
1982 CJ7
I had never seen one on a CJ either untill doing a tranny conversion for a customer. He had a conversion bell housing from Advanced adapters (350 to T-4), I'm going to assume the throwout lever and bearing were from them too. The bearing had a grease fitting and was serviceable. No real way to get at it without pulling the tranny. Maybe thru the throwout arm hole with a flex hose and some luck...Anyways ,the bearing was way loose, and looked as if it were pumped full of grease it would eventually sling out. It got replaced with the sealed type and a recomendation to just replace when it goes bad.
jeepmaster03 is offline
post #11 of 14 Old 02-21-2010, 07:03 PM
bleoh
The one I got from Parts Mike for my T18 swap has a grease fitting. IIRC it was a Luk clutch kit.
bleoh is offline
post #12 of 14 Old 02-22-2010, 09:28 AM
MontanaCJ5
1974 CJ5
The grease zerk was pointing straight down. That's why I decided it would be easy to drill a small hole and be able to access it with the hard line off a grease gun.
post #13 of 14 Old 02-22-2010, 10:14 AM
Mike Romain
Or through the boot with a hard line and a 90 fitting? If that didn't work, I would drill the hole for sure.
Mike
post #14 of 14 Old 02-22-2010, 10:18 AM Thread Starter
dangjeep
After checking mine out, there is nothing I can do to it now. The bearing is wasted and needs to be replaced.....
dang
dangjeep is offline
3rd Throwout Bearing Replacement - Why? fraser86laredo Jeep CJ Forum 6 08-15-2009 06:43 AM
Sound like throwout bearing..BUT ! 4d9r Jeep CJ Forum 3 04-15-2008 05:21 AM
Throwout bearing HELP!! atom73 Jeep CJ Forum 9 02-23-2008 07:54 PM
Throwout bearing going bad. JeepinYahoo Jeep CJ Forum 16 04-16-2007 01:55 PM
throwout bearing CJ5911 Jeep CJ Forum 19 02-24-2006 02:24 PM
