Greasing The Hubs on Full Floating Dana 44s? - JeepForum.com
post #1 of 2 Old 07-25-2010, 03:01 PM Thread Starter
Darthteddy
1955 M-38
Low and behold im missing the Dust Cap off the end of my full floater hubs on one side of my willys. Theres clearly grease around the spines and stuff but im not sure if this is something that needs it regularly or just on initial installation? Theres not supposed to be a Zerks fitting or something on the end of the axle shaft is there? Or do I need to take it all out and grease occasionally?
And also, The 6 bolts that hold the drive flange on always wiggle themselves loose. Ive tried locktite, Thread sealer. and even RTV. They have new lock washers on them so i dont see why they come out almost to the point of falling out. The other side has never done it before, but these are almost completely out after maybe 50 miles or so.
Dylan-19 and Yearning
93 Rubigrand - Sold... :'(
95 Grand Cherokee Limited - 5.2 Mall Crawler
55 Willy's M38a1 - 231v6, 33" Super Swampers, D44 Full Floater Rear, Locked Front and Rear, 5.38 Gears, Viair OBA, Bilsteen 5100 shocks, Dana 18, Turbo 350, S10 Power Steering, Tilt-wheel, Full Cage, Flat Fenders....
Darthteddy is offline
post #2 of 2 Old 07-25-2010, 04:02 PM
BlueRubiconrich
Like the front hubs, I use lock washers. There is a cup like cap that goes over the end.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
axle , dust cap , full floater , full floating , grease , hub , lube , lubrication
will the full-time lock hubs on older cj-s replace lockout hubs? jeepin cj-5 Jeep CJ Forum 2 04-23-2008 07:27 PM
Warn full floating rear axle Houdini Jeep CJ Forum 7 07-23-2007 03:25 AM
Full floating axles is it worth the price? davidsc Jeep CJ Forum 4 05-16-2007 02:00 AM
full floating rear axles? offroadjunkie Jeep CJ Forum 2 03-21-2006 05:03 PM
Greasing Hubs Jack-Jack Jeep CJ Forum 3 09-19-2005 07:31 AM
