Grease in rear break assembly - JeepForum.com
post #1 of 8 Old 01-29-2013, 11:26 PM Thread Starter
Renegade578
1981 CJ7
I noticed brake fluid leaking on my right rear tire, so I assumed I had a bad wheel cylinder. I removed the drum to take a look and found the entire brake assembly covered in grease. I'm attaching a few pictures. I also found several broken springs. I can't figure out where all this grease came from. I removed all everything to inspect the axle bearing and it looks to be okay. I have 2 theories. One, someone thought the bleeder valve was a grease nipple and pumped the the full of grease. Two, the PO was too lazy to fix the rear brakes so he covered everything with grease since the rear brakes only do about 20% of the braking anyway. Any other ideas?
IMG_20130129_191932.jpg   IMG_20130129_191938.jpg   IMG_20130129_192035.jpg   IMG_20130129_210620.jpg
Renegade578 is offline
post #2 of 8 Old 01-30-2013, 12:00 AM
roboto65
1976 CJ5
Not grease most likely, gonna say you are right and it is brake fluid that has mixed up with the dust and created what looks like grease but is not. The wheel cylinder is probably shot and thats what is causing that.
They say money can't buy happiness but it can buy Jeep parts...and Jeep parts make me really Happy.
roboto65 is offline
post #3 of 8 Old 01-30-2013, 01:14 AM
82JeepCJ7
1982 CJ7
Been there, done that. Inner seal was leaking.
(Axle is an AMC 20 rear with a Warn full float kit)
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 8 Old 01-30-2013, 09:43 AM Thread Starter
Renegade578
1981 CJ7
That is definitely a possibility. It did smell a little like gear oil. I don't think it is just brake fluid mixed with dust. It is thick and really feels like grease, so I could see it being gear oil mixed with dust. So I will have to remove the axle shaft to replace the inner seal right? Is it necessary to replace the axle bearing while I have it out? I don't have access to a press and my budget is limited with a baby on the way
post #5 of 8 Old 01-30-2013, 11:22 AM
Coiz
1979 CJ7
Your brake shoes are on the wrong sides, they should be swapped front to back. The shoe with the longer friction material should always be toward the rear of the vehicle like in your second "greasy" picture.
Originally Posted by 82JeepCJ7 View Post
Mike
Coiz is offline
post #6 of 8 Old 01-30-2013, 01:03 PM
82JeepCJ7
1982 CJ7
Yea, I noticed that as well and corrected it after I took the picture.
post #7 of 8 Old 01-30-2013, 04:34 PM
cj5huntingrig
1974 CJ5
Bad seal. Go ahead and check play in your bearings. If they are sloppy, they will just wear out new seals.
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #8 of 8 Old 01-30-2013, 06:02 PM
Bubba Ray
Gear lube leaking from rear end. Smell it and u will know.
Bubba Ray is offline
