Grand wagoneer axle swap question about width?? - JeepForum.com
post #1 of 10 Old 07-30-2012, 08:38 PM Thread Starter
turbonusse2
I was looking into getting wider axles for my 7 and was wondering how wide the wagoneer axles are and what points you measure from?? also when you do this do you generally need to get diffrent legth driveshafts?
turbonusse2 is offline
post #2 of 10 Old 07-30-2012, 08:41 PM
81CJ7V8
1981 CJ7
Wheel mounting surface to wheel mounting surface. You'll probably have to change front driveshaft out, but rear should be fine. there are alot more experienced people than I about the driveshafts, but for width, wheel mount surface, or WMS to WMS.
81CJ7V8 is offline
post #3 of 10 Old 07-30-2012, 09:59 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
If you are staying sua with the same springs, your existing driveshafts might work. Now is the time to go SOA though...just sayin...
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #4 of 10 Old 07-31-2012, 05:08 AM
Oldcraneguy
1982 CJ7
If you decide to go SOA you might wanna look for an early bronco rear, theyre already setup that way and they measure 58" wms and 36"(much like wide tracs) between perches and best of all its a 9" Ford, stout to begin with and GOBBS of aftermarket support even if your looking for full width the F150 9"s are plentiful. even though my 20 w/moser axles has held up so far with 38.5s Im prepping a 9" to replace it with once I get the 360/304 swap done....OCG
OH almost forgot, youll have to outboard your springs up front for waggy axle, and if memory serves (which is iffy) the waggy axles are 63" wms and you need to find early ones that have pass side drop (im thinkin early 80s and back) guluc OCG
Oldcraneguy is offline
post #5 of 10 Old 07-31-2012, 07:37 AM
RobsCrawlin7
no balls
the waggy axles you want are late 70's for the front and anything 80 and newer for the rear (as long as they are not out of a quadratrac). remember that the newer waggys had both the d44 and the hd amc 20 rears, both are strong. The hd amc20 is stronger but the d44 has a much better aftermarket support.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
1 April 2007
post #6 of 10 Old 07-31-2012, 08:21 AM
Oldcraneguy
1982 CJ7
You didnt mention your wheels, if your planning on new ones it doesnt matter but if youd like to keep the ones you have you need to check and see what the waggys use, Im thinkin the later ones might be 6 lug, it was another reason I chose the 9" they use the same 5x5.5 as my CJ and I love my bullet holes....OCG
post #7 of 10 Old 07-31-2012, 08:31 AM Thread Starter
turbonusse2
I think your right about the 6 lug. I know you can get parts for 5x5.5 but im sure they cost a pretty penny
live and learn
post #8 of 10 Old 07-31-2012, 08:36 AM
CSP
Any '74 and up fullsize Cherokee or Wagoneer/Grand Wagoneer is six lug.
'80 and up front axles have the diff on the wrong side for a CJ. The narrow track FSJ axles are about 4" wider than CJ wide track. All Waggies/Grand Waggies are narrow track. Only the Cherokee Chief and pickups were widetrack.
Find the WMS to WMS widths of all of them at www.jeeptech.com
CSP is offline
post #9 of 10 Old 10-12-2012, 08:52 AM
jkgrrrbaby
Ihave a 93 xj, I'm wanting to.do.a 8.8 in rear, but have not made desision on front yet, would the 44 out of an 87 waggy work for front end matched with 8.8. Thanks in advance.
jkgrrrbaby is offline
post #10 of 10 Old 10-12-2012, 08:55 AM
CSP
Yes it would, though the lug pattern would be different. Next time you should be asking XJ questions in the Cherokee forums, not CJ.
CSP is offline
full width axle swap help RobsCrawlin7 Jeep CJ Forum 9 12-01-2010 06:19 PM
87 jeep grand wagoneer v8/auto swap over to 86 CJ-7 jamesclees Jeep CJ Forum 2 09-20-2010 09:56 AM
help with full width gm axle swap rusty83cj Jeep CJ Forum 3 05-14-2009 09:41 AM
track width on cj, axle swap, fender coverage. spk454 Jeep CJ Forum 5 06-24-2008 05:51 AM
cj 5 Full width axle swap summitking Jeep CJ Forum 0 05-25-2008 06:44 PM
