Got the TBI installed, but have ignition questions - JeepForum.com
post #1 of 11 Old 07-07-2010, 05:41 PM Thread Starter
Hillbillyd
1980 CJ5
Got the Affordable Fuel Injection kit installed over the weekend, everything went great. Jeep starts and runs down the road fine, but seems to miss at idle. It did this with the carb setup too, I just always kinda blamed the carb. The ECM doesn't have any codes, and check engine light stays off, so that's why I suspect ignition. I haven't upgraded the ignition, all stock stuff. It does have new plugs, wires, cap, and rotor though. But while idling, the engine shakes, and is generally not smooth. Checked for vacuum leaks, timing, etc. I'm going to do the team rush upgrade on the cap, rotor, and wires, and use an e-coil. I think this will help alot, but I'd like to have a multispark cdi unit as well. I'm not sure if that will work though with the fuel injection setup? The way I understand it, the ECM controls the spark now, so is it multispark already? If not, how would I wire in a multispark cdi unit?
Hillbillyd is offline
post #2 of 11 Old 07-08-2010, 06:35 AM
BioTex
1979 CJ7
IMO, you would be way better off simply taking the upgrade in steps.
For instance:
Install the cap, rotor, wires and regap new plugs to .045".
Then get the timing set and see if the miss is still there. If so, do a compression test, and see if you perhaps have a weak cylinder.
Post back, and let us know. If you change out too many parts all at once, you open up a can of worms.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #3 of 11 Old 07-08-2010, 10:09 AM
1986cj
You didn't get a dist with your kit or have not done no mods to yours?
1986cj is offline
post #4 of 11 Old 07-08-2010, 12:09 PM
CSP
I was curious about the same thing. Since the AFI kit controls spark you have to disable the mechanical and vacuum advances. Did you do that part?
CSP is offline
post #5 of 11 Old 07-08-2010, 12:54 PM
1986cj
Afi's kit for a 304 comes both ways, new mod hei for spark or not, just like Howells kit.
1986cj is offline
post #6 of 11 Old 07-08-2010, 05:20 PM Thread Starter
Hillbillyd
1980 CJ5
I sent them my distributor and they modified it to wire into their harness. Other than that, it's still stock.
post #7 of 11 Old 07-08-2010, 10:32 PM
1986cj
Did they put a GM control module in the mod dist? was it a HEI or do you still have a duraspark dist.
1986cj is offline
post #8 of 11 Old 07-09-2010, 05:21 AM Thread Starter
Hillbillyd
1980 CJ5
No, it's still the stock distributor. They just changed the wiring to wire into their harness.
post #9 of 11 Old 07-09-2010, 05:23 AM Thread Starter
Hillbillyd
1980 CJ5
I just left the vacuum unhooked to it.
post #10 of 11 Old 07-09-2010, 08:09 AM
CSP
What about the mechanical advance? I would assume that they disabled that along with wiring mods (which amount to adding a plug to the wires that were already there).
Have you been in contact with AFI yet?
You can add a multiple discharge cdi to your setup, but I wouldn't expect it to solve a drivability issue.
CSP is offline
post #11 of 11 Old 07-09-2010, 08:33 AM Thread Starter
Hillbillyd
1980 CJ5
I actually have sent AFI an email, but they haven't responded yet. I'll call them later.
TBI , ignition , install
TBI & Ignition questions boomvader Jeep CJ Forum 3 01-11-2010 02:58 PM
engine will not start just installed new ignition coil seedubau Jeep CJ Forum 9 08-02-2009 09:52 PM
79 CJ5 ignition questions nd4spdbh Jeep CJ Forum 63 07-23-2008 06:06 AM
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 05:56 AM
installed new ignition, carb & manifold on my 304 Marc CJ7 Jeep CJ Forum 4 05-26-2004 05:58 PM
