-   -   Got my MC2150 dialed in... (http://www.jeepforum.com/forum/f8/got-my-mc2150-dialed-1466036/)
capt205 01-19-2013 05:40 PM
Title says it. Got the 2150 from the ebay guy, install was pretty straight forward, new DUI at the same time, but had a nagging bog, hesitation, stumble...something, when taking off, and when accelerating with slight pedal from cruising speed.
Checked timing many times, with light, and vacuum guage as well as mixture adjust, choke adjust. Just couldnt get rid of the stumble. Checked the power valve, and it held with a vacuum pulled on it. Played with accelerator pump linkage position and holes. Still no joy.
Decided to try using some of the PV and jetting combos that worked for others here, and went from the 8.5 PV and 49 jets, to a 6.5 PV and 47 jets. Now runs like a scalded dog, accelerates smoothly with none of the afore-mentioned issues, and pulls hard to 75mph with the new 4.56's, at which point I let off. Also noticed that the smelly rich fumes are significantly reduced...really, they are not noticeable anymore.
Just wanted to share the combo that worked for me at basically sea level in Florida.
RedRaiderCJ7 01-19-2013 05:50 PM
Thanks for the post, Ive been thinking of doing this myself. I have a pretty good stutter about halfway through the throttle and all of the ignition has just been upgraded/replaced. What is the guys name that sells them on ebay?
-Mason
capt205 01-19-2013 06:45 PM
Ebay sellars name is ehrmannmp
19in1979 01-19-2013 07:55 PM
He's a good guy to deal with. Give him specifics (I live a 8,500 ft elevation for instance) and he will pre-tune the carb. Mine arrived and was plug & play and required very little adjustment.
rainjeep 01-20-2013 12:31 AM
I have the same problem (rich fumes gas smell) with my 2150 carburator on my 258 engine and bought it from the Ebay guy also. I have done pretty much everything you described: fuel air mixture settings, new vacum hoses, no gas leaks around the tank, reconect charcoal canister, choke adjustment etc.I don't even know what size jets i have now but I would like to try different ones, i've never worked on the internal parts of a carburator before. What is a 6.5 PV? Did you have to remove the whole carburator off the jeep to change te jets or can it be done on the jeep? where did you get all the parts needed? Do you have a write up for this? thanks for the help
capt205 01-20-2013 07:36 AM
Got the 6.5 power valve from NAPA, and the jets ordered on line.
You have to take the carb off to change the PV. Its on the bottom front, under the little cover held down by 4 screws. The jets are easy to change with the carb on or off, but you do have to take the top off the carb to change them. I suggest picking up a jet tool, as the slot can get boogered if you are not careful.
capt205 02-19-2013 12:15 PM
As an update...
Getting GPS verified 15-18mpg depending on my right foot pressure application. This is figured over 4 visits to the gas station, topping off the tank, and calculating mileage.
I think the carb is doing good now.
walkerhoundvm 02-19-2013 12:27 PM
Did you let Mike know what you had to do? Did he cover the costs? There are others around the internet that have similar problems, perhaps he doesn't know about them and keeps making the same mistake?
capt205 02-19-2013 02:48 PM
That's a good idea...I'll send him an email with what I did.
Other than that, I'm pleased with the carb. I know I could have done some legwork myself and saved a few bucks, but this was about as simple as it gets...new carb, gaskets and adaptor with studs, 1 transaction, and pretty good install notes as well, if you need them.
Matt1981CJ7 02-19-2013 04:38 PM
Hey Wayne,
Do you happen to know what jetting/air combo he put in yours?
We should start keeping a database of jetting combos that work with each carb at certain elevations. A few shops offer custom-jetting , but I don't sense any of them have it dialed in. Too many variable, perhaps.
National carbs in another excellent company to deal with. They custom jetted my carb for no extra charge. The primaries were perfect, but i did need to tweak the secondaries.
Op, congrats. I know how satisfied you must feel. :cheers2:
Matt
19in1979 02-19-2013 05:39 PM
Originally Posted by Matt1981CJ7 (Post 14998376)
Hey Wayne,
Matt
Matt -
I can't tell you what he did specifically to mine as it got lost in the conversation. We chatted on the phone for a bit and since he's down in Colorado Springs we talked about me driving the CJ down there and he'd jnstall and tune it for the schitz & giggles of it.
I had to decline his kind offer since I didn't want to break down half way there if the carb that I was replacing found out that he wasn't coming home with me.
Actually, I had already pulled the old carb off or I would have taken him up on it.
I do like your idea of a data base though but it would have to be searchable. Is there a way that it could be done here on the forum? I fear if we do it as just a sticky with folks adding info as they get it, it would take a lot of reading just to find what's pertinent to you. Maybe ask up the food chain a bit?
DUX4LIFE 02-19-2013 06:52 PM
Got a part number?
capt205 02-20-2013 03:51 PM
Originally Posted by DUX4LIFE (Post 14999295)
Got a part number?
I don't, but the counterman just opened the Holley book, picked out the one I was asking for, and they had it upstairs.
I'm working a double today and tomorrow, but I'll see if I still have the package with the pn on Friday when I get home...I have a long day in the garage then as I'm repairing the oil cooler and replacing the water pump and radiator on my 2003 F350 7.3 PSD.
DUX4LIFE 02-20-2013 05:23 PM
A part number would be great a I tried to look it up online at NAPA's site but couldn't locate it. I wasn't looking for Holley though as I didn't know if they were the same as the motorcraft. Since I don't have the vac line going to the PV does that mean mine is a single stage?
wm69 02-21-2013 10:09 AM
If your power valve has a bowl on it it's likely a 2 stage. If it's flat it's a single stage.....
I have both types. Tagged for more info on best PV to use. Getting black smoke out of one carb when I mash it (46 jets, unknown PV) and the other one runs great (47 jets, unknown PV).
I've always just used the PV that came in the rebuild kits, but they never have any markings on them.
The time now is 10:06 AM.
