Got the MC2100 installed BUT - JeepForum.com
post #1 of 13 Old 03-28-2010, 06:53 PM Thread Starter
Forumpete58
Got the MC2100 installed today, BIG thanks to Beachedjeepyj, he was a big help and I really appreciate him taking time out of his weekend to help me! Here's my question...We got the carb installed and I can tell a good difference over the carter but mostly in the top end. I still feel I'm missing a lot of low end power in my CJ. I'm planning on doing the TeamRush upgrade this week, I'm really hoping this helps. Another problem is that I may still have a vacuum leak. Beachedjeep tested the vacuum pressure and the needle was jumping quite a bit between 15 & 20lbs. Problem is that we thought we got all the vacuum lines hooked up or blocked off.
Forumpete58 is offline
post #2 of 13 Old 03-28-2010, 07:13 PM
Trapshooter
The vacuum leak is most likely you low end problem. You need to resolve the leak issue before you do anything else. Lets think about this for a second...vacuum is what advances the timing.
Good luck..........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #3 of 13 Old 03-28-2010, 07:44 PM
Olrev
1981 CJ7
Yep, find your vac leak first. If you don't know the propane trick, learn it. Propane trick - Jeep Wrangler Forum. Once you get that nailed, you will want to start playing with the accelerator pump, trying each of the "holes" (test driving). Usually, you can find a setting that will cure the low end issues. If that doesn't do it, you can try some different jets...bigger and smaller. I've ended up with 51's in mine, which is big/rich for most daily drivers but it works great in my application. I did the TeamRush and added the lighter springs to my distributor and I'm amazed at how much grunt I get. As long as you don't have anything bigger than the 1.08 you should be able to get it to idle smooth as butter and it should climb trees below 500rpms. I'm actually gonna try a 1.02 and see if I can milk some more low end out of mine.
81CJ7, 258, MC2100, TeamRush'd, 3"lift, 34x10.50TSL's, 3:31gears, Scrambler cab
Olrev is offline
post #4 of 13 Old 03-28-2010, 07:59 PM Thread Starter
Forumpete58
I snapped some pictures of how its set up. Maybe you guys can shed some light on this.
Thanks!
post #5 of 13 Old 03-28-2010, 08:17 PM
Olrev
1981 CJ7
Hard to tell much from the pics...vac leaks are hard to see. Try spraying carb cleaner around to find your leak. Honestly, I think you will find your problem in your ac. pump adjustment.
Olrev is offline
post #6 of 13 Old 03-28-2010, 08:20 PM Thread Starter
Forumpete58
Stupid question but "ac. pump adjustment"?
post #7 of 13 Old 03-28-2010, 08:28 PM
Trapshooter
Accelerator pump........is my guess.
My 401 build:
post #8 of 13 Old 03-28-2010, 08:39 PM
Skerr
Yep, find your vac leak first. If you don't know the propane trick, learn it. Propane trick - Jeep Wrangler Forum...
I did this for the first time after installing my MC2100. Crank her up, and using a hand-held cylinder, open the valve and move it around any place that might be questionable. The idea is that the leak will pick up the propane and your engine will smooth out. Get a cylinder at the local hardware store, ~$4. Don't forget to get the nozzle. They are generally sold separate.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #9 of 13 Old 03-28-2010, 08:39 PM Thread Starter
Forumpete58
Ohh ok thanks, I bought my carb as a set off ebay and was under the impression that they came pre-tuned.
post #10 of 13 Old 03-28-2010, 08:42 PM Thread Starter
Forumpete58
I actually JUST bought one of those small propane tank/torch sets. I'll see if I can determine anything tomorrow.
Thanks!
post #11 of 13 Old 03-28-2010, 08:51 PM
Skerr
One other thing that could help. I went throught this with my MC2100... I installed it with the Mr. Gasket adapter plate. Using the propane, I discovered significant leaks around the base of the carb. After I pulled the carb back off, I discovered that the MG plate was much smaller than the carb base, and I had used only the gaskets that came with the adapter. You have to use the larger gasket designed for the 2100 on top of the adapter. Otherwise, you'll never eliminate the vacuum leaks. It was explained to me by another JF member. Hope it helps you.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 13 Old 03-28-2010, 09:02 PM
VACJ7
VACJ7's Avatar
^^^ What he said! The thin gasket between the carb and adapter is useless. There is a thick one you can get at any parts store for about $4. I bet if you spray brake cleaner around the base of your carb you will find the leak.
VACJ7 is offline
post #13 of 13 Old 03-29-2010, 09:04 PM
Olrev
1981 CJ7
The gasket you're looking for is a felpro #60716...it's actually called a "phenolic spacer".
The Accelerator pump (sorry for the abbreviation earlier) adjustment is critical and if you're gonna run a 2100 you're gonna have to learn how to tune it. You will see a rod on the drivers side of the carb (or the side that your linkage hooks up/opposite side of the choke). That rod actuates the accelerator pump in the front of the carb. It should connect to your linkage on a small bar with 4 holes in it. Which hole you put the rod into determines the fuel delivery amount during early acceleration. Usually the second or third hole works the best but you will want to try each and test drive it.
Olrev is offline
Anyone interested in a free installed MC2100 carb? chiliman77 Jeep CJ Forum 1 02-18-2009 04:44 PM
Just installed a MC2100 WOW its like EFI neals80 Jeep CJ Forum 8 02-11-2009 07:16 PM
New MC2100 ishcak Jeep CJ Forum 9 08-12-2006 12:39 AM
MC2100, umm, is this right? bcar240 Jeep CJ Forum 2 07-25-2005 04:56 PM
Installed MC2100. TOO MUCH FUEL! dreski1 Jeep CJ Forum 4 06-25-2005 08:41 PM
