Got the CJ started but can't shut it off! - JeepForum.com
post #1 of 3 Old 09-03-2012, 08:20 PM Thread Starter
bigdee2
It's been a ten month project, so wires have gotten crossed and I've forgotten where some thin go go surely.
I did a few upgrades:
1. Removed the old ignition system, dizzy and coil - went with a HEI for the AMC - the only connection required was a 12 volt on/off with the key/ignition.
2. Changed on the silenoid - probably my issue.
Right now, the wire to the starter is on one side (larger terminal) with the small blue wire on the smaller terminal. The battery cable + is on the other large terminal along with the wire to the alternator and the fuseable link to power the fuse box under the dash. The small red wire is on the smaller terminal next to it. With this set-up, it will power up the ignition and crank, but the engine will not turn off!!
If I swith the larger wires around to the opposite sides of the larger terminals on the silenoid, the starter continously engages.
Then the small purple wire is going to the oil sending unit and the lower passenger side of the block and a small purple wire with a stripe is going to the temperature unit mounted on the intake.
Any thoughts?
bigdee2 is offline
post #2 of 3 Old 09-03-2012, 08:52 PM
cjjon7
1983 CJ7
Your sense wire on the alternator is not hooked up properly. This is what tells the alternator to shut off when you turn the key off. Search for threads on here they are plentiful
cjjon7 is offline
post #3 of 3 Old 09-03-2012, 09:02 PM
VACJ7
VACJ7's Avatar
Look at your starter solenoid. The small posts are labeled I (ignition) and S (start). The small red wire goes to the I post and the blue wire to the S post.
'84 CJ-7 |
VACJ7 is offline
wiring , wiring diagram
CJ 5 Won't Shut Off Tuts Jeep CJ Forum 2 04-30-2012 06:13 PM
CJ shut off whilst driving... but started back up? Fletch8672 Jeep CJ Forum 2 05-12-2009 11:26 AM
MSD 6T won't shut off with key gojeepin Jeep CJ Forum 15 08-27-2008 09:10 PM
Won't shut off??? dali555 Jeep CJ Forum 5 10-18-2004 01:25 PM
Help!! CJ-7 258 intermitent shut shut off brownrecluse Jeep CJ Forum 4 08-08-2004 11:11 AM
