post #16 of Old 10-24-2003, 11:56 AM
kurdt
kurdt's Avatar
Originally Posted by txfireplug
Thanks for the imput. I really dont mind paying for it to drive right. Whats the best source of suspension components? Any brand get recomendations? O, and slap the **** out of your neighbor for me.
hey, a couple of things... have you checked the steering box mount itself? the cjs use a cheap two piece stamped steel mount and the bolts work loose all the time if you use it offroad. a steering box brace and a new steering box mount from M.O.R.E or poison spyder would help that... they make the mounts out of 1/2 inch thick steel and it's one piece. another thing, the steering shaft in cjs can lead to a huge amount of slop/play in the steering. flaming river and borgeson make a beefy replacement steering shaft. might wanna throw some new tierods on or just upgrade while you're at it.
http://www.spydercustoms.com/index2.html has either heim or tierod end replacement draglink and tierod kits for CJs that are way beefier than your stock little steering system. other than the steering box mount, a brace, a steering shaft or the tierods... i can't really think of much else someone hasn't mentioned that would cause what you're talking about... usually if it's sloppy, it's just plain sloppy.
oh, and as far as a shackle reversal... i think it does make for a smoother ride and it allows you to run a slightly longer shackle for a bit better flex, or even a buggy spring... i installed one on my CJ before i went coilover... however, i really didn't notice a huge improvement in steering. a shackle reversal allows the shock of an impact (bump, whatever) to travel backwards in the direction it's already traveling as the spring compresses, thereby giving a smoother ride... however depending on how arched your springs are, a shackle reversal can be advantageous or not worth your effort. the flatter your springs are the less a shackle reversal will help. here is a good article on shackle reversals that explains it more in depth.
http://www.off-road.com/jeep/tech/susp/elkcahs/
note: the server side has some retrival errors... you may need to try the link a few times, i assure you the page is there as of this writing
-kurdt
00 Lexus GS300
97 Suburban 6.5 Turbo Diesel 6" lift 35" BFG A/Ts
81 CJ-7 rock buggy, injected 350, built th350, 3.8 atlas II w/ ebrake, d60 front 1.5 stubs w/ detroit, 4.88 gears, discs, d70 rear w/ detroit, 4.88 gears, discs, 37" krawlers, 17" trailready beadlocks, 16" king coilovers, 4 link f/r, 12+ point cage, howe full hydraulic steering, fabbed by owner :D
kurdt is offline
Stearing Tie Rod Bent Into A V Shape? brandon007 Jeep CJ Forum 5 03-29-2009 01:17 PM
Replacing Stearing shaft boot, can not get apart RichmondCJ7 Jeep CJ Forum 1 02-17-2009 09:40 AM
power brakes and stearing in a CJ7?? blacktj27 Jeep CJ Forum 9 02-02-2006 12:52 AM
Stearing Box 80CJeep Jeep CJ Forum 3 10-07-2004 04:42 PM
About my stearing Crazywillis85 Jeep CJ Forum 2 07-15-2004 07:31 AM
You may not post new threads
You may not post replies
