Is good stearing possible??? - JeepForum.com
post #1 of 16 Old 10-14-2003, 07:27 PM Thread Starter
txfireplug
OK, so I know that CJ's stearing sucks. Is there anyway to make it so that the jeep feels good while driving over 55 MPH? Any aftermarket parts to do this? There isn't alot of slack in the stearing the jeep just has a mind of it's own once it hits the highway. Any suggestions are welcome.
txfireplug is offline
post #2 of 16 Old 10-14-2003, 08:10 PM
Dtray332
Well, before I can start to make any suggestions. Have you done anything to your jeep, like lift shackles or a lift kit? Has your steering always been like that or did it just start?
1986 Renegade CJ7, 258 straight 6, 4 inch Pro Comp lift, 33 inch Super Swampers (TSL Radial), Double Trail Master steering stabilizer, cool set of aircraft seat restraints.
Dtray332 is offline
post #3 of 16 Old 10-14-2003, 08:13 PM
eight
eight's Avatar
Are you useing lift shackles? Those make the jeep drive bad because they mess up the caster. Other than that, installing a track bar will help.
eight is offline
post #4 of 16 Old 10-14-2003, 08:17 PM Thread Starter
txfireplug
Thanks DTRAY,
No It's pretty much sucked since I bought it. Its an 86 CJ, with 33's. The damn thing is horrible on the highway. Id really like it to run good on the highway so I don't have to tow it to the deer lease everytime I go. I know the short wheel base isn't the most condusive to high-speed handling but it realy sux. Any input would be great.
post #5 of 16 Old 10-14-2003, 08:22 PM Thread Starter
txfireplug
Hey 8,
No no shackles, btw HOWDY. Your in my neighborhood.
post #6 of 16 Old 10-14-2003, 08:27 PM
Dtray332
What eight said is right, if you have lift shackles, it will mess up your camber. You have 2 options then, either grind off your spring perches and rotate your axle back and reweld them in place. You can also put shims between the spring and the perch. If you are going to do any serious off roading, I would go ahead and reweld the perches. The say that the cast shims can break and come out. I have never actually seen it happen, but it is possible.
Dtray332 is offline
post #7 of 16 Old 10-14-2003, 08:34 PM Thread Starter
txfireplug
Thanks,
Anyother suggestions? I will do whatever it takes to make this damn thing stable.
post #8 of 16 Old 10-14-2003, 08:47 PM
Dtray332
One other, check the U bolts. It is possible that they are lose or came lose at one time and the guide pins on the spring perches came out of the holes in the springs and let the axle rotate forward.
Dtray332 is offline
post #9 of 16 Old 10-14-2003, 08:56 PM
only in a jeep cj
This may sound crazy, but what pressure are you running in the 33's? If your contact patch is too small, the jeep reacts more to the heavier rotating mass of tires and tends to bounce off the small bumps in the road. This was the problem in my buddies CJ with 33s. He lowered the pressure (from 35 to 23 or so) and said it was a world of difference. Also check the wear in the box, tie rods and front bearings as these Jeeps aren't getting younger and have both milage and age against them. I'm running pretty much all stock and it tracks better with speed. Yes, I can take my hands off the wheel (even at higher speeds) and it tracks great. I'm stable up to 90mph or so.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #10 of 16 Old 10-14-2003, 09:01 PM
rustyCJ
"steering"
you're running 33s? you have a lift? what kind of angle is the draglink compared to the tie rod? why is it only bothering you over 55? have you checked all your rod ends, ball joints, steering box, steering shaft, and steering column for any kind of play?
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #11 of 16 Old 10-14-2003, 09:02 PM
Lightningdon
Lightningdon's Avatar
" I'm stable up to 90mph or so." If my CJ is doing 90mph, it's because I just drove over a cliff! Call 911!
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
post #12 of 16 Old 10-14-2003, 09:28 PM
only in a jeep cj
I know, it sounds strange, but I run 75 to 80mph all the time and it does it just fine. Running 265/70/R15 dunlop rover AT's at 25 psi in the front and 23 psi rear, with 3.31s , 5th gear and 258 engine (165 thousand miles).....I credit the tires matching the power band of the engine (I believe it's 2500rpm at 75mph). Hard top must be on as due to a low pressure drag, I can only do 70 (= OR -) with the top off.
Now I have a CJ-6 that you couldn't pay me to drive over 50mph in it! and its a longer wheelbase (104) It's just a whole different feeling creature. Not all CJ's are the same. Each one I drive has it's own "feel" .....some I trust, others I don't.
Ed
1975 CJ-6 1983 CJ-8
post #13 of 16 Old 10-14-2003, 09:35 PM Thread Starter
txfireplug
Thanks for the imput guys. I guess I will try changing the tire pressure. I believe that the tie rods are fine and everything else seems to be ok. I will check everything over again tomorrow.
post #14 of 16 Old 10-15-2003, 06:47 AM
wm69
Have you thought about a shackle reverse? This is something I've thrown around, but I don't do highway much in my jeep anymore. I worked with a guy who had a shackle reverse and he said it was night and day in the way his jeep drove. Also, I thought my steering box was in good shape, but replaced it with an AGR superbox 2 when I got the engine built. It drives a whole lot better now (course for what the agr box/pump costs it ought to!) Just a couple of thoughts. I also have heard that your front u joints (in the axles, not on the driveshafts) will wear and cause sloppy steering. Another thing to look at. This is a problem common to a 20 year old jeep. If you want good steering you can replace u joints, ball joints, steering box, and tie rod ends, and it should drive great (at a pretty hefty price). It is possible for a jeep to drive well on the highway. The guy down the street had an 86 with 19K miles on it and it drove like a caddy (and he sold it for 5500 with HT/ doors and a warn 8274 on the front, no rust, paint like new, renegade package, don't get me started on missing that one). I personally would look at the shackle reverse first, they're about $200 (or you could try to make it yourself).
wm69 is offline
post #15 of 16 Old 10-15-2003, 07:55 AM Thread Starter
txfireplug
Thanks for the imput. I really dont mind paying for it to drive right. Whats the best source of suspension components? Any brand get recomendations? O, and slap the **** out of your neighbor for me.
Stearing Tie Rod Bent Into A V Shape? brandon007 Jeep CJ Forum 5 03-29-2009 01:17 PM
Replacing Stearing shaft boot, can not get apart RichmondCJ7 Jeep CJ Forum 1 02-17-2009 09:40 AM
power brakes and stearing in a CJ7?? blacktj27 Jeep CJ Forum 9 02-02-2006 12:52 AM
Stearing Box 80CJeep Jeep CJ Forum 3 10-07-2004 04:42 PM
About my stearing Crazywillis85 Jeep CJ Forum 2 07-15-2004 07:31 AM
