Good Start/Hard Start/No Start - JeepForum.com
post #1 of 3 Old 05-25-2010, 06:14 AM Thread Starter
tigercreek
Long time user of a similar forum - new here.
Here is my setup. No computer/emissions. Clean, well maintained CJ
1984 258 w/2100MC, MSD 6a, TFI Coil, Team Rush Upgrade.
Upgraded to the MSD last year and swapped out my several times rebuilt 2100 for a newer, freshly rebuilt 2100. The CJ had been running like a top ever since. Lately it has sat for a month here and there without being used. Recently started to use it on a more regular basis and it became harder to get it to start
This morning I could not get it to start at all so I decided to quit messing around an fix it. Checked and verified the MSD, coil, carb shooting good fuel, plugs ok, verified timing/ TDC.
Pulled the distributor cap (brass) and found a little corrosion on the electrodes. Cleaned it off and pulled the #1 plug for a spark test. Had my wife turn it over while I looked. Turned over twice and it was running and shorting on the block before she could shut it off. Figuring I had fixed the problem (corrosion in the cap) I buttoned everything back up and went to start it up.
Nothing. Same as before. Crank, crank, crank - won't even cough.
How could it fire and run with the #1 plug out and do nothing with it all back together? Is this a clue? Ground?
I have since tested for spark through the distributor and I'm getting nothing. Suspecting a bad stator - but could this be ground related? I plan to readdress all of the grounding routes when I get home but I'm looking for some thoughts.
tigercreek is online now
post #2 of 3 Old 05-25-2010, 06:38 AM
Mike Romain
The stock ground is the hold down foot on the distributor so adding a dedicated ground to the black wire coming out of there is a good thing to do.
The stock pickup in the distributor can be tested using an ohm meter. Orange and purple should show between 400-800 ohms with 600 being nicest between them. Neither of those wires should show continuity to ground.
Mike
Mike Romain is offline
post #3 of 3 Old 05-25-2010, 07:48 AM Thread Starter
tigercreek
Confirmed bad stator.
Pulled stator had --- for ohms. That's bad.
New replacement from NAPA 624 ohms.
Plan on adding additional/dedicated ground to the stator.
The fact that it started with the plug pulled and grounded still has me wondering.
258 hard to start ivaskaj Jeep CJ Forum 2 08-01-2009 06:51 PM
hard to start Hank86 Jeep CJ Forum 3 06-23-2008 10:02 AM
AMC 360 hard start jp360cj Jeep CJ Forum 4 02-09-2008 09:15 AM
My ignition is being stubborn, engine doesn't start in "start" position scrible Jeep CJ Forum 6 10-04-2007 10:04 AM
Hard start CJ-7 shaibi Jeep CJ Forum 7 08-04-2005 11:08 AM
