Is this is a good deal? 1983 Jeep CJ7 - Page 6 - JeepForum.com
post #76 of 81 Old 11-09-2012, 05:01 PM Thread Starter
matthewleeblair
1983 CJ7
matthewleeblair is offline
post #77 of 81 Old 11-10-2012, 12:46 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Originally Posted by matthewleeblair
... the blinkers do not work. I guess I'll have to track down the fuse and check that...!
a very, very common problem. you may need to perform work in many areas, but in my experience you should do the following...
change bulbs
replace blinker module (relay)
clean bulb mounting bases. use sandpaper if corroded. use dielectric grease if needed.
the brake light and turn signal light housings have connectors just downstream from them. pull those apart and remove corrosuon.
replace fuses
my fuse block had light corrosion. i used an old fuse and worked it in and out to grind it off. i may have used electrical contact cleaner on it w battery disconnected. or use dielectric grease to pick up the debris and wipe it away.
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #78 of 81 Old 11-10-2012, 04:02 PM Thread Starter
matthewleeblair
1983 CJ7
Well... I was just looking at things under the dash today, before I read your reply, and after fooling around down there (didn't change anything out, just checked some connections) the blinkers work haha. Who knows?
Thanks for the tips though!
post #79 of 81 Old 11-10-2012, 04:52 PM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Glad it's working! Be prepared for it to stop working at any time until you find the problem.
Ken4444 is offline
post #80 of 81 Old 11-13-2012, 07:04 PM
papa355
1977 CJ7
blinker fluid low ?
1977 CJ7, 360 AMC with HEI, TH400 quadratrac, dana30, AMC20, SOA, 35" M/T MTZ
papa355 is offline
post #81 of 81 Old 11-13-2012, 10:47 PM Thread Starter
matthewleeblair
1983 CJ7
Hahaha... I knew I was forgetting something lol.
cj7
