Good Combination for 4cyl cj7? - JeepForum.com
post #1 of 12 Old 06-23-2013, 12:30 PM Thread Starter
93Trip
Hey yall,
Just got my jeep back from having a new clutch assembly put in, and I found out that my jeep has what the mechanic called a Dana 20? Transfercase. It also has the Dana 44 axles, with a 4cyl engine, and 4 speed tranny. Is all this a good combo?
Thanks,
Trip
93Trip is offline
post #2 of 12 Old 06-23-2013, 01:42 PM
row684
Originally Posted by 93Trip
Hey yall,
Thanks,
Trip
what year is it?
row684 is offline
post #3 of 12 Old 06-23-2013, 01:44 PM Thread Starter
93Trip
1986
93Trip is offline
post #4 of 12 Old 06-23-2013, 02:12 PM
jp360cj
1977 CJ7
Post some pics of the Trans, tcase, and axles. Factory would have been a Dana 300 tcase, Dana 30 front axle, most likely a T4 transmission, and either a Dana 44 or AMC20 rear axle.
Not saying your mechanic is wrong, because anything could have been swapped in. need pics to verify, but I would be surprised if someone swapped the drivetrain and left 4cyl.
The D20 and D300 are both good cases but the D300 has lower low range gears from the factory and better aftermarket support.
Some D44 fronts are much stronger than the D30, some are only marginally stronger. Also if the swap was done poorly it could cause more problems than it fixed.
The T4 is not a desirable transmission, but if you have a D20 then you don't have a T4.
You'll get opinions all over the place about the D44 vs AMC20. I have ran both and have torn up the carriers in both, so IMO an amc20 with 1 piece shafts is about as good as aD44
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is online now
post #5 of 12 Old 06-23-2013, 02:17 PM
nixer600
Im not saying your mechanic is wrong, it's possible he is right, but most likely wrong.
Sent from AutoGuide.com Free App
nixer600 is offline
post #6 of 12 Old 06-23-2013, 08:32 PM Thread Starter
93Trip
Here are some photo's I took today, but I'm not sure how much help they will be.
93Trip is offline
post #7 of 12 Old 06-23-2013, 08:44 PM
spottedfrog
1979 CJ5
I'm gonna say: D44 rear, D30 front, D300 T-case, and I cant ID the trans. likely a T4. There is an ID tag visible on the front D30 as long as it hasn't been changed it will tell you the Axle gearing.
spottedfrog is offline
post #8 of 12 Old 06-23-2013, 09:15 PM
jp360cj
1977 CJ7
x2
post #9 of 12 Old 06-25-2013, 05:28 AM
jetmech1
I'm pretty sure the 4 cyl. CJ's came with 4.10 gears from the factory. My 86 CJ7 did.
jetmech1 is offline
post #10 of 12 Old 06-25-2013, 06:20 AM
jp360cj
1977 CJ7
IIRC, the 4cyl were std with 3.54 with 4.10 optional. BUT I could be mistaken
post #11 of 12 Old 06-25-2013, 08:26 AM
Boomer
1982 CJ8
This is correct.
Boomer is offline
post #12 of 12 Old 06-27-2013, 05:00 AM Thread Starter
93Trip
Mine has the 4:10 gears. I've driven it about 45 miles this week, and I've had to put in $30 worth of gas
Its starting to sputter every now and then when driving in 4th gear going down the road, thinkin it might be a float in the carb?
93Trip is offline
