Going NUTS!!! - JeepForum.com
post #1 of 16 Old 06-23-2013, 07:00 PM Thread Starter
dleone
Going NUTS!!!
Ok. I have a 86 CJ7 with 258.. The jeep ran fine except for a little miss. I decided to tune it up with new basic autolite plugs/plug wires/distrubutor cap/rotor button and fuel filter. got done replacing everything and decided I probably should have let it alone. Now the thing runs VERY rough (missing)and VERY rich??? Why would this happen?? It seems to be missing almost like its out of time? but why all the sudden would it do this?? Do I have to re punch the distributor? I checked and tripple checked all connections and
I have been messing with this thing all day and had to quit before I put a bullet in it.. Please help if you can!!
Semper Fi
dleone is offline
post #2 of 16 Old 06-23-2013, 07:07 PM
lucdog
1980 CJ5
Double check to insure the plug wires are correct.
B
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #3 of 16 Old 06-23-2013, 07:12 PM Thread Starter
dleone
Did that several times..
dleone is offline
post #4 of 16 Old 06-23-2013, 08:52 PM
pman
Put the old wires back on and see what happens.
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #5 of 16 Old 06-23-2013, 10:09 PM Thread Starter
dleone
I actually put everything but the old plugs back
dleone is offline
post #6 of 16 Old 06-24-2013, 03:26 AM
jp360cj
1977 CJ7
Did you check the gap on the plugs before installing?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #7 of 16 Old 06-24-2013, 04:11 AM
BagusJeep
1981 CJ7
Have you got the cap properly screwed down. Believe it or not it is possible to have it in there but not properly in place.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 16 Old 06-24-2013, 05:56 AM
CJ7VFR
Did you check the timing?
Or did any of the vacuum advance hoses come loose? Check the three
vacuum switches on the firewall behind the engine. Sometimes those
can come loose and give you problems.
Also, check that the vacuum advace hose to the dizzy is connected and
not clogged.
If your Jeep was running fairly good before your tune-up, then something
must have either come loose, changed, or you have a bad new part somewhere.
You'll find it. Just go thru everything you did, and triple check!!
Good luck!
Jim
CJ7VFR is offline
post #9 of 16 Old 06-24-2013, 07:16 AM
lucdog
1980 CJ5
The only thing you changed that would cause this problem is the plug wires in the wrong location. There is also the possibility of bad parts, not likely thou.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #10 of 16 Old 06-24-2013, 12:37 PM
waterdowg
With owning Jeeps for over 20 years, I have found with the stock ignition to use only Champion copper plugs. My sister had a tune up done on her 96 Cherokee and they used Autolite plugs. It ran like crap, they wanted to do other work. I told them to replace the plugs with Champions. If it didn't fix the issue I would pay for for the new plugs a labor. Well, it fixed this issue.
waterdowg is offline
post #11 of 16 Old 06-24-2013, 09:41 PM
GrnLvs
1978 CJ7
Remove spark plugs & make sure they are properly capped. Also check your firing sequence.
GrnLvs is offline
post #12 of 16 Old 06-24-2013, 10:23 PM
Dngrs1
1979 CJ7
Shoot yourself in the head----you obviously can't work on Jeeps!
Just kidding! Walk away for two days and check--recheck everything you did.
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #13 of 16 Old 06-28-2013, 10:47 PM Thread Starter
dleone
ok.. I took out the PCV valve and it wil run kinda ok but you obviously gotta keep your foot on it to keep it running.. i shook the valve and it still rattles however when I put the vaccum hose on the valve while the jeep is running it kills it.. I have no idea what the hell changed on this thing.
dleone is offline
post #14 of 16 Old 06-29-2013, 06:21 AM
keith460
Jeep. There's Only One
keith460's Avatar
That sounds like a vacuum leak to me.
Do you have a vacuum gauge to check for leaks and to use as a diagnostic tool? You may have dislodged a vacuum hose or one of them could have been dry rotted and was about to go and fiddling in and around the engine may have finally cracked it open.
1984 CJ-7 Renegade
keith460 is offline
post #15 of 16 Old 06-29-2013, 07:40 AM
thompsoj22
odd, inducing a vac leak makes it run?
so you pull the vac hose to the pcv and it runs, you plug/install it and it dies?. kinda go's against the basics. do you have an EGR valve? if so make sure it is closed and not hung open and leaking air . im with the majority, it must be in the area you were working, cap, rotor, wires, plugs. "no good deed go's unpunished", you didnt think that your jeep was going to thank you for a little TLC did you?. you will find it, it will be somthing simple. check the nipple inside the cap that conducts the coil voltage to the rotor. consider new parts as "bad". look at cap/rotor closely. ok so i read your first post again, is the choke closed?. this would create a "runs better with vac leak symptom". is the choke working properly?, rich condition is absolutely carb, it missed before the tune, do a compression check or have someone keep it running and pull plug wires one by one to isolate the bad cyls if there are any. yes you may get a little shock but shock therapy has been found to be productive in some human faults.
thompsoj22 is offline
