GM corporate axles - JeepForum.com
post #1 of 5 Old 02-16-2005, 07:14 PM Thread Starter
Ezredcj
Ezredcj's Avatar
1980 CJ7
GM corporate axles
Anyone using corporate axles? I have an oppurtunity to buy a 79 3/4 ton chevy with a corporate 14 bolt rear (10 1/2" ring gear) and a corporate 10 bolt front . 4.10 gears. I'm working on a 350 swap in my cj and I'm wondering if any one has done this? Or have any feed back.
I can get this truck very cheap. Hopefully $200 to $300. would it be worth trying to use the axles?
Ezredcj is offline
post #2 of 5 Old 02-16-2005, 07:40 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'd say it depends on what your overall plan is for the Jeep and how much fabrication skills/$$$ you have. Anything is "possible" but "practical" is another story. That would be a pretty good setup for a trail rig. That 10 bolt is about as strong as a Dana 44 and probably good for up to about 35"-37" tires under a CJ. The 14 bolt is super tough.. but it's big too. If you run that 14 bolt with something like 35" tires, you'll be dragging a$$ over everything. You could shave the bottom to help a little. The axles are also wide. Your tires will stick out pretty far. You'd need to outboard the front spring hangers for the front axle. For the rear, you'd just need to move the spring perches. A plus is that both axles are setup for SOA already. Plus, the 10 bolt has at least a flat top knuckle on the driver's side (don't know about the passenger side) for a high steer setup that you'd need with the SOA. If it were me.. I would do it. I'd use that 10 bolt until it breaks. Probably toss in a lunch box locker. In the meantime, I'd save pennies for a front Dana 60 to better match the strength of the rear 14 bolt (the Dana 60 would then be a bolt-in swap for the 10 bolt). I'd run at least 39" tires on Hummer beadlocks. Scoot the rear axle back as far as possible for best driveshaft length/angle. Scrap the 14 bolt's rear drums and switch to disks (about the cheapest disk conversion of all the rear axles). Also, toss a Detroit into the 14 bolt (cheapest/easiest axle to swap a Detroit into too). In the end.. you'll wind up with something that will be worth about 1/3 of what you spent on it..... but it'll be fun to drive! I'm doing something similar with my CJ5 but using the Dana 60 front...
BESRK is offline
post #3 of 5 Old 02-16-2005, 08:53 PM
RoostrRiz
Only thing to watch out for with that 14 bolt is if it is equipped with a factory locker. As far as I know you cannot use a detroit in a factory locked 14 bolt due to differences in the cases between open and factory locked rears. And I think most people are familiar with Eaton's lockers lackluster performance.
RoostrRiz is offline
post #4 of 5 Old 02-17-2005, 06:57 AM
CJ51973
CJ51973's Avatar
Performance Offroad in Alexandria, KY had used Hummer rims about a year ago . (859)-635-3058 ask for Roy. BTW...BESRK, your CJ5 looks awesome & unstoppable. What's the wheel base now? What suspension front and rear?
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #5 of 5 Old 02-17-2005, 10:47 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Thanks for the kind words.. wheelbase now is 99". It's still the SOA up front with 1.5" RE springs. The rear is a dual triangulated 4 link with Fox 14" coilovers. I've finally got all the link stuff and crossmembers done. Now I'm sorting out spring rates to get the correct ride height/travel/firmness. Next year I'll probably 3 link/panhard the front and move it forward another 3-4 inches. I hope to have it back on the trail by April so I can make a Spring run to Paragon.
BESRK is offline
How do I fit a corporate ten in the front of my CJ-7? jfrdog Jeep CJ Forum 5 11-19-2008 07:44 PM
cj7 axles in a cj5? tawdr77 Jeep CJ Forum 5 09-29-2008 06:02 AM
Corporate 10 bolts greaseboysjeeps Jeep CJ Forum 7 02-26-2008 08:36 PM
corporate 10 bolts dave_dj1 Jeep CJ Forum 4 11-04-2006 12:43 AM
AMC Corporate 20 Rear Axle Hub turbogus Jeep CJ Forum 6 06-11-2005 08:31 PM
