glasspack - JeepForum.com
post #1 of 7 Old 05-31-2002, 12:32 PM Thread Starter
KG4PAM
Post glasspack
does anyone have a glasspack muffler on their jeep? i got one the other day, but it was too long and had bends in the end pipe(cherry bomb brand) any suggestions on mounting it? i think im gonna order a shortyer one from summit, and a cat. how loud does it make the jeep? also do you like the tone? thanks! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline
post #2 of 7 Old 05-31-2002, 01:52 PM
Brock
Brock's Avatar
Post
On my '89 Wrangler with a 258, I had the cat gutted (Alabama doesn't check emissions, so I just wanted it to appear straight) and a 24" glasspack muffler put on. It just has a really deep, mellow tone. Not loud at all, but remember, the shorter the muffler, the louder it gets. Also really helped performance and throttle response.
Brock is offline
post #3 of 7 Old 06-01-2002, 10:07 AM Thread Starter
KG4PAM
Post
thanks i appreciate the reply! yeah, a guy i know said that someone he knew put one in a chevy and it soulded about like a flowmaster. thanks again! btw, do you know if hollowing the cat actually hurts emissions test performance?
KG4PAM is offline
post #4 of 7 Old 06-01-2002, 11:01 AM
scottahicks
scottahicks's Avatar
Post
I have flow tech Purple hornies on my cj5 mine are the header type with the turn down on it. it is LOUD but that is also because mine are the 3" and im runing two straight off the headers. flowtech makes a couple diffrent types, look on jegs.com and they have all the lengths etc you might also want to look for some mini turbos there a tiny version of the turbo muffler I realy loved those good noise reduction at idle and low rpm but when you get on it they get wicked. i would have those on mine now but i tore my original set but by staping my driveshaft and the drive shaft ripped through them. so as a cheap fix i cut out the exhause and bolted the glasspacks direct to the headers
good luck
kg6cpz
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline
post #5 of 7 Old 06-01-2002, 11:08 AM
scottahicks
Post
a very very well tuned engine with low miles can pass an amissions test without a cat on it or a hollowed out cat but a cat does do its job when functioning properly and you run a much lower risk of failing an emissions test. the idea of a cat is to burn the excess unburn fuel and gasses befor the exhaust leaves the tail pipe if you are running rich and dont have a cat your shure to fail,, just depends on your setut and your areas test requirements as to specific emissions levals
post #6 of 7 Old 06-02-2002, 12:32 AM
MR.CJ-7
Post
I run the "header muffler" style of cherrybomb that bolts right to the header collector, from there it is a short piece of tail pipe and out the side of the CJ. It is very loud. Never a prob with emissions without my cat.
Former CJ'er
MR.CJ-7 is offline
post #7 of 7 Old 06-02-2002, 09:33 PM
hollywood
Post
I run a pipe with a factory bend from the manifold to a Cherry Bomb which hangs half in and half behind the transfer case skid pan. It basically sounds like a UPS truck ...just a little louder.
- Jeff
'83 cj
Another 7 by "CJ's Heaven"
hollywood is offline
Cherrybomb glasspack SeaWulf Jeep CJ Forum 32 04-06-2009 12:06 PM
header exhaust glasspack 76CherokeeChief Jeep CJ Forum 3 08-11-2005 10:51 PM
Glasspack length recc. Dimension4 Jeep CJ Forum 6 08-07-2005 09:47 PM
