Getting rid of end play on amc 20 axle (HELP!!) - JeepForum.com
post #1 of 5 Old 08-11-2002, 09:08 AM Thread Starter
Bryan L.
right side has one shim ( no way of measureing) But maybe a .005, the left side had the same sized shim and the backing plate and drum rubbed when I'd turn right. Do I add or take away shims?
Bryan L. is offline
post #2 of 5 Old 08-11-2002, 09:45 AM
Jeep Daddy
Jeep Daddy's Avatar
What are you doing? Putting in new axles? new bearings? new seals?
I got new one piece Genuine Gear axles for my AMC20 and it had instructions for the shimming and the tolerances. I don't have the instructions with me because a friend of mine is using them to install the axles at his work.
If you are just installing new bearings, or new seals, you shouldn't have to worry. Just press it all together and you should be done. If you have something rubbing, you probably didn't seat the bearing all the way down, or you pressed it on too far. I remember reading in my axle instructions not to press the bearing past the raised part of axle. That is where the seals goes.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #3 of 5 Old 08-11-2002, 10:58 AM
80cj
80cj's Avatar
1980 CJ5
Re: Getting rid of end play on amc 20 axle (HELP!!)
Bryan,
I understand the left brake is the one thats rubbing. How much clearance is there between the right backing plate and drum? If there is sufficient room between the right drum and backing plate I would take the shim from the right side and put it on the left side thereby allowing the left axle to stick out further but you will only be gaining .005". Did you check your total axle shaft end play? Jack both rear wheels off the ground and check it with a dial indicator. My 80 CJ manual says there should be between .004 to .008 endplay with .006 being desireable. I guess it may be difficult to get an accurate actual reading if you have interference with that brake drum. Hope this helps.
80cj is online now
post #4 of 5 Old 08-11-2002, 12:25 PM Thread Starter
Bryan L.
I put in new seals, bearings, and one new hub. (we destroyed the other one trying to get it off.) When we pulled every thing apart the left side had 1 thick shim and 2 real thin shims and the right side had 1 thick shim. When we put it back together I didn't put the 2 thin shims back in becuase they were rusty. They were so thin that I didn't think it mattered that the weren't in there. I have 3 new shims that parts place let me have, they are the thick ones. (I have no way of measuring the shims) Should I add theseto the left side? What is definition of end play? I"M STUPID Thanks for all the help!!!!
Bryan L. is offline
post #5 of 5 Old 08-11-2002, 02:24 PM
80cj
80cj's Avatar
1980 CJ5
Bryan
With the rearend of the Jeep off the ground and wheels off do the following:
1. Make sure the brakes are not dragging. Adjust the shoes so they don't contact the drums or remove the drums.
2. Push in and out on one axle. There should be a very slight amount of play. This play is the "end play".
One more thing comes to mind. the service manual says that when you install a new hub, the hub is properly installed when the hub is 1 5/16 inch in from the end of the axle. Did you check this measurement? I don't know if it is possible to screw the hub in further than this but if it is in more than 1 5/16 inch then that may be your problem.
If you need to talk send me a private message with your phone number and I would be happy to give you a call.
80cj is online now
Rear Axle end play GwenStrough Jeep CJ Forum 11 01-26-2014 10:03 AM
axle side to side play ovaldrivnaz Jeep CJ Forum 3 11-28-2008 11:23 AM
Should there be end play on Dana 30 axle shafts? fromme Jeep CJ Forum 9 01-31-2006 07:03 AM
Play by play for tranny removal pookie Jeep CJ Forum 2 03-27-2005 03:35 PM
Axle Play Question? Shop is trying to bull-=-=-=-=-=-=-=-= me... Hale Jeep CJ Forum 8 03-28-2004 03:08 AM
