Getting desperate for guidance - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Getting desperate for guidance
Zone Offroad Body and Suspension Lift Kits, Brackets, DiscJeep Wrangler Framless, Bowless, Trektops 92-95 YJ, 97-06 Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 08-01-2015, 10:06 AM   #1
Splinter
1980 CJ5
I am ready to assemble the heads on my freshly machined 360. I have been searching for weeks for some basic instructions. The thing is most of the info I find says to install head gaskets dry. I will be installing Fel Pro gaskets and the instructions tell me to apply sealant to the metal side contacting the block. However I cannot find any sealant recommended for head gaskets or gasoline. Any Comments would be appreciated. Thanx
Splinter is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 10:17 AM   #2
holliewood61
1981 CJ7
Im sure some copper spray would be just fine
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is online now   Reply With Quote Quick reply to this message
Unread 08-01-2015, 10:19 AM   #3
CSP
x2 on copper spray
CSP is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 11:03 AM   #4
Splinter
1980 CJ5
That's what I'll do. Q. on both sides, metal and fibre?
Thanks for the responses.
Unread 08-01-2015, 11:49 AM   #5
swatson454
1983 CJ7
Interesting gasket and I can't say I've ever seen one like that. Copper spray on metal-to-metal works well. What's on the other side (I'm guessing gasket-to-head contact)? Can you snap a pic of both sides?
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 01:13 PM   #6
LumpyGrits
Cj
X3 on copper spray.
This has work'd very well for me.
http://www.permatex.com/products-2/p...sealant-detail
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 08-01-2015, 01:37 PM   #7
Splinter
1980 CJ5
[IMG][/IMG]
Shawn
Unread 08-01-2015, 01:55 PM   #8
swatson454
1983 CJ7
Yep, unless they specify something else, I'd say copper spray on the bottom and dry on the top. Don't forget to seal the threads of any head bolts that hit water with high-temp RTV.
Shawn
Unread 08-02-2015, 12:21 AM   #9
Mortgage-payer
1976 CJ7
I used to make extra money in college rebuilding Mercedes diesels 30 years ago. Think of them as having your head gasket problems x10.
We had a few come back with blown head gaskets until we started using the Permatex copper spray. Then that problem just stopped.
I call it a distributor, not a dizzy.
Mortgage-payer is online now   Reply With Quote Quick reply to this message
Unread 08-02-2015, 12:29 AM   #10
AZ_Chip
1981 FSJ Cherokee
Dang those are some sexy pistons!
1981 Jeep Cherokee Chief S
AZ_Chip is offline   Reply With Quote Quick reply to this message
Unread 08-02-2015, 06:56 AM   #11
keith460
Jeep. There's Only One
keith460's Avatar
Yah, copper spray is good.
1984 CJ-7 Renegade
Restoration Thread:http://www.jeepsunlimited.com/forums...d.php?t=434226
keith460 is online now   Reply With Quote Quick reply to this message
