general 258/4.0 question - JeepForum.com
post #1 of 4 Old 09-23-2011, 09:26 PM Thread Starter
Zorm
1983 FSJ Cherokee
Picked this up today at the Summit scratch and dent bin http://www.summitracing.com/parts/CCA-K68-235-4/ (didn't pay that much for it though) I am asking if this cam setup would be worth putting im my engine. What I have is 4.0 HO head on a 258, ran it for the past 5 years. Now I am putting on a 2000 intake along with fuel injection and a 62mm throttle body.
Any cam guys out there know what I can expect from this cam in set up?
thanks
Zorm is offline
post #2 of 4 Old 09-24-2011, 08:39 AM
gosupes
The specs for that cam say that it's not for fuel injection. It's a fairly agressivve cam for the 258. Would be interesting to see how it worked.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #3 of 4 Old 09-25-2011, 01:36 PM
james04si
james04si's Avatar
1977 CJ5
I have the comp cams high energy with the 260h grind and it is not supposed to be for fi either. I'm running it with a Howell tbi and it runs great. I also have the 4.0 head and those springs will not work with it because the retainers are a different size than came on the 258 head. I ended up using the stock springs on the 4.0 head and have had no issues so far. And as far as performance its much better than my original 232,much more get up and go when I need it.
james04si is offline
post #4 of 4 Old 09-25-2011, 01:40 PM
james04si
james04si's Avatar
1977 CJ5
Ohh yeah and that timing chain may or may not fit under your timing cover. I called comp cams when mine lacked about .020" of fitting and they said it was a known issue with some of the timing covers but couldn't tell me what years fit and which ones don't.
258 Head Torque Spec/Pattern: General Question cj5mudman4x4 Jeep CJ Forum 8 06-20-2011 09:26 AM
general trivia question duggerinc Jeep CJ Forum 4 10-16-2010 03:21 PM
novice..... general question littleturner76 Jeep CJ Forum 6 10-08-2010 01:26 PM
Just a general question about towing with a jeep.. TheJunkMan2005 Jeep CJ Forum 18 08-02-2005 07:14 AM
