Gearshift Sloppy? - JeepForum.com
post #1 of 7 Old 08-02-2004, 08:09 PM Thread Starter
ColtsFan
Gearshift Sloppy?
CJ7 Troubleshooters -
Need advice on what to do with a (suspected) faulty part. Shifter in T4 tranny can be simply lifted up & handed to the passenger (not good). Attempts at caveman manipulation of metal sleeve have only made situation worse (even more play). Suggestions from the masses? Don't see part readily available in any of the parts catalogs. Help!
ColtsFan is offline
post #2 of 7 Old 08-02-2004, 08:23 PM
wm69
There's a plastic sleeve that goes between the stub that sticks up out of the tranny and the metal clip. When the plastic wears out the clip doesn't hold the shifter on there anymore. Get a new plastic thingy and a new metal clip and you should be good to go. It will REALLY make a difference. Only bad part is you have to get the part at the stealership. I still think it was only like $10-15 bucks though.
wm69 is offline
post #3 of 7 Old 08-07-2004, 08:41 PM
sircampsalot2
sircampsalot2's Avatar
Did you ever find the plastic shims for the stick shift? I'm needing some of those things too
83' CJ7 limited
258 Inline 6
33x12.50x15 Super Sport Radial HT's
Diamond Plate Rockers and Corners
2 KC Daylighters
4" RC Lift
Heavy Duty Steering Shaft
T-4 Tranny 300 Transfer case
[____]
OIIIIIO
[]=o=[] http://img.photobucket.com/albums/v226/sircampsalot2/000_0005.jpg
sircampsalot2 is offline
post #4 of 7 Old 08-08-2004, 08:30 AM Thread Starter
ColtsFan
Parts Found
Yes, parts have been found. Was ordering new sheetmetal & asked if they carry the part. Was in luck. Got the parts at WillysOverland. Apparently a very common problem in jeeps of age & miles. Email me direct if you can't locate the needed parts & I'll get you in contact with who you need.
ColtsFan is offline
post #5 of 7 Old 07-22-2007, 06:57 PM
ronaldm201
Same thing happened to me
Shifted into second this afternoon and gearshift came off in my hand. I have a 84 CJ7 with the T4.
Looks like the metal clip is broken, and the "plastic sleeve" had been replaced by the PO with some sticky rubber tape. I don't see these parts at WillysOverland. Anyone got any ideas?
ronaldm201 is offline
post #6 of 7 Old 07-22-2007, 07:53 PM
wm69
check with your local dealership. That's where I got mine, and the parts weren't very expensive.
wm69 is offline
post #7 of 7 Old 07-23-2007, 09:08 AM
JoonHoss
2011 JK Wrangler
another (great) option is to tack weld a nut on two sides over a drilled hole, and use two set screws to hold it in place.
My Jeeps's PO tried the duct tape fix too, with the same results.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
73 CJ gearshift knob Smitttykid Jeep CJ Forum 6 06-03-2009 08:23 PM
sloppy shifter vmaxup Jeep CJ Forum 8 09-18-2008 12:19 AM
sloppy steering Fuzz21 Jeep CJ Forum 5 03-30-2005 08:20 PM
Sloppy T5 Transmission johny1i Jeep CJ Forum 3 02-01-2004 07:26 PM
sloppy steering NJCJ7 Jeep CJ Forum 2 10-01-2003 08:15 AM
