Gears - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Gears
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 04-12-2008, 10:01 AM   #1
spk454
1983 CJ8
Gears
I am replacing my 2.73's (why did jeep do this???!!!) with 4.56's. wanted to do one axle at a time (rear amc20 1st) dana 30 2nd. I know I can't use 4wd like this, BUT if i leave the transfer case in 2hi and the manual hubs unlocked there's no problem right? A guy at work told me there would be damage to the vehicle but I can't see how. Since my frame isn't ready for wheelin and snow and ice are not an issue in MD this time of year I'd like to do one at a time as i get the cash...
spk454 is offline   Reply With Quote
Unread 04-12-2008, 10:22 AM   #2
cscotted
1980 CJ7
theres nothin wrong with doing it one axle at a time...Just dont ever lock the front end in and put it in 4 H or L. until front and rear match.
cscotted is offline   Reply With Quote
Unread 04-12-2008, 10:24 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
With the hubs unlocked, the front diff and axles are stationary.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 04-12-2008, 06:37 PM   #4
Bard
My 2 cents on this for the way you are going to do this, pull the front drive shaft off until it is complete. Less apt for a mistake with the t-case shifter.
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline   Reply With Quote
Unread 04-12-2008, 08:01 PM   #5
Exerdoc
Along these same lines (gear changing!), the AMC 20 requires a new carrier for any ratio above the 2.73. So, will a Detroit locker be a good choice? If not, what are some recommendations? And, does the Dana 30 (front) need a carrier change to go to 4.56?
T
Exerdoc is offline   Reply With Quote
Unread 04-12-2008, 08:20 PM   #6
80cj
80cj's Avatar
1980 CJ5
That's what I did when I changd my gears. Did the rear first and ran them for a month then got off my lazy butt and did the front. Stay out of 4 wheel drive and you got no problems.
80cj is offline   Reply With Quote
