gears - JeepForum.com
post #1 of 39 Old 05-13-2013, 07:28 PM Thread Starter
Newbjeep
1972 CJ5
gears
do I have 4.27 gears
Newbjeep is offline
post #2 of 39 Old 05-13-2013, 09:11 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
divide 41 by 11
3.73
jeepdaddy2000 is offline
post #3 of 39 Old 05-13-2013, 09:15 PM Thread Starter
Newbjeep
1972 CJ5
Ahh now makes sense I thought it was just the first three numbers on the left
Newbjeep is offline
post #4 of 39 Old 05-13-2013, 09:24 PM Thread Starter
Newbjeep
1972 CJ5
Newbjeep is offline
post #5 of 39 Old 05-13-2013, 11:37 PM
jeepdaddy2000
1971 CJ5
When in doubt, do a tooth count.
post #6 of 39 Old 05-13-2013, 11:44 PM Thread Starter
Newbjeep
1972 CJ5
How do I post a video I want y'all to see how awesome my rear spider gears are
Newbjeep is offline
post #7 of 39 Old 05-14-2013, 12:00 AM
lucdog
1980 CJ5
Your going to have to put it on YouTube and post a link.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 39 Old 05-14-2013, 11:31 AM Thread Starter
Newbjeep
1972 CJ5
http://youtu.be/Zk4n2S6qfiM
Newbjeep is offline
post #9 of 39 Old 05-14-2013, 03:42 PM Thread Starter
Newbjeep
1972 CJ5
What gears can I put in my jeep with out changing the pinion I want some where around 4.00 what's the closest gears to that?
Newbjeep is offline
post #10 of 39 Old 05-14-2013, 03:44 PM
Elias4WDCenter
3.73s
Sales, Service & Installation - Suspension, Accessories, Wheels and Tires, Recovery Gear, Bumpers. WE SET UP AXLES, GEARS and LOCKERS. (And we'll work on your mother-in-law's Honda so you can wrench on your Jeep!) 978-597-8432 Mon - Thurs, 8 a.m. to 6 p.m.
Townsend, MA. Tell us Jeep Forum sent you!
Elias4WDCenter is offline
post #11 of 39 Old 05-14-2013, 03:49 PM
SLO_Ken
Gears are sold as a matched set. They come with a ring gear and a pinion gear that are factory matched as a pair.
I think you mean you don't want to change the carrier, in which case, you should be okay using the same carrier up to 4.56:1 gears. I believe 3.73 is the cutoff, where anything higher (lower ratio gears, such as 3.31) would require a different carrier.
edit: The carrier break above is only for Dana 30 front differential. For the Dana 44 rear that you likely have in your CJ, 3:73 is the lowest gearset for that carrier. Anything lower (higher numerical ratio) will require a new carrier.
edit 2: The D44 axle has many gear ratios available, from 3.07 to 5.89. The closest to 4.00 that you are looking for are either 3.92 or 4.11.
SLO_Ken is offline
post #12 of 39 Old 05-14-2013, 03:59 PM Thread Starter
Newbjeep
1972 CJ5
Does any one know a good guess on how much it would be to rehear and install and limited slip in rear and locker in front
Newbjeep is offline
post #13 of 39 Old 05-14-2013, 04:00 PM Thread Starter
Newbjeep
1972 CJ5
Dow Any one know the cost of changing gears and adding a limited slip in rear and locker in front
Newbjeep is offline
post #14 of 39 Old 05-14-2013, 04:08 PM
jeepwhore
It can vary by region but to have a competent shop do it I'd say $200-$300 per axle for gears and install kits and the same again for labour is a pretty safe number. If it were me I'd plan to spend $1000 just for the re-gear. Add onto that what the lockers you want will cost.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #15 of 39 Old 05-14-2013, 04:12 PM
SLO_Ken
Shop time around here is $80-$100 /hr. A good guesstimate is ~4-6hrs shop time plus materials per axle. A decent gearset is ~$200 ea, plus $200 ea in new bearings, seals, etc. The locker/limited slip are ~$600 ea.
So, all totaled, you're looking at ~$2000 in parts and another ~$1000 in labor.
edit: As stated above, shop rates can vary widely by region. Shop around to get a feel for pricing in your area.
SLO_Ken is offline
