Gearing Set up Advice Please - JeepForum.com
post #1 of 12 Old 09-17-2011, 09:59 AM Thread Starter
batcave4
Right now my 86 CJ is set up as a 3.43 in a DANA 44. Trouble is I cant find a limited slip carrier to replace the damaged one. Any advice on what I should should set up as instead.
batcave4 is offline
post #2 of 12 Old 09-17-2011, 10:05 AM
W7NB
Tell us a little more about the jeep and how you use it - tire size, any other mods. Do you use it in the winter as a DD, is it a mall crawler?
I would be more likely to go with something like a Detroit Softlocker or a selectable locker if I had the factory LS carrier I needed to replace. 3:43 suck any way you look at it unless you are running stock tires.
°lllll° Am I broke yet??
1985 CJ7 With HO 4.0 Conversion
2013 JK
W7NB is offline
post #3 of 12 Old 09-17-2011, 10:17 AM Thread Starter
batcave4
Background, right now it has 32" tires but they are done and the rims are garbage as well so those will be getting tossed.
Also will only be doing some trail riding, plan to use it as a daily driver in the summers in WI and store it in the winter.
batcave4 is offline
post #4 of 12 Old 09-17-2011, 11:01 AM
gojeepin
1983 CJ7
I was unaware of a 3.43 for the Dana 44.
I show...
Ratio: Teeth per ring/pinion
2.87: 43/15
3.00: 45/15
3.07: 43/14
3.23: 42/13
3.31: 43/13
3.50: 42/12
3.54: 46/13
3.73: 41/11
3.92: 47/12
4.09: 45/11
4.27: 47/11
4.56: 39/8
4.78: 43/9
4.89: 44/9
5.13: 41/8
5.38: 43/8
5.89: 53/9
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
post #5 of 12 Old 09-17-2011, 11:05 AM Thread Starter
batcave4
Yeah, mechanic just called...its the 3.23.
batcave4 is offline
post #6 of 12 Old 09-17-2011, 01:02 PM
80cj
80cj's Avatar
1980 CJ5
Differential carrier breaks for a Dana 44 are 3.73 and lower and 3.92 and higher. You need a 3.73 carrier/LS unit.
80cj is offline
post #7 of 12 Old 09-17-2011, 08:02 PM Thread Starter
batcave4
Thanks for the help so far. Anyone have a lead on this carrier in LS?
batcave4 is offline
post #8 of 12 Old 09-17-2011, 08:26 PM
80cj
80cj's Avatar
1980 CJ5
LS is Limited slip. there are many limited slip options available for a Dana 44. Among the best is the Trutrac which is gear driven and does not require any special oil or friction modifier and is pretty much transparent on the street. The strongest is the Dana-Spicer Power Lok which is a friction clutch type with 4 spider gears and does require limited slip compatible oils and sometimes friction modifier depending on how tightly it is setup. Others include the Dana Trac Lok and Auburn to name a couple more. In my experience, the Trac Lok is the least effective.
80cj is offline
post #9 of 12 Old 09-18-2011, 03:22 PM Thread Starter
batcave4
Thanks for the help everyone, went with the trutracs and a 3.73 setup. Pic of whats its going into.
batcave4 is offline
post #10 of 12 Old 09-18-2011, 03:49 PM
W7NB
Sounds like a good combo. As long as you are staying with the 32's the 3:73 gears will be fine.
2013 JK
W7NB is offline
post #11 of 12 Old 09-18-2011, 04:23 PM Thread Starter
batcave4
I sure hope so.
batcave4 is offline
post #12 of 12 Old 09-18-2011, 06:08 PM
BSInc
You'll love the truetracs after your first trail.
BSInc is offline
How do I check my gearing and what gearing would I need? reundo Jeep CJ Forum 6 07-22-2010 12:31 PM
Need some advice on re-gearing namredla Jeep CJ Forum 10 08-06-2009 07:10 AM
Gearing advice sought- please bear with me... 4BTCJ3A Jeep CJ Forum 6 01-01-2009 01:46 PM
gearing ? maine jeepster Jeep CJ Forum 2 10-18-2007 08:48 PM
Gearing gl437 Jeep CJ Forum 3 09-29-2006 11:12 AM
