Gearbox fluid removal - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Gearbox fluid removal
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Alloy usa heavy duty ball joint kitsENGO QUADLUX 6" to 54" LED AMBER AND WHITE MULTI
Unread 07-19-2014, 05:35 PM   #1
AZ_Chip
AZ_Chip's Avatar
1978 CJ7
1978 CJ7, Tried to search, no help. Is there a way to remove gearbox fluids without plate removal? Do the handheld vacuum pumps work? Does it get the old fluid out? Thanks,
AZ_Chip is offline   Reply With Quote Quick reply to this message
Unread 07-19-2014, 11:11 PM   #2
RenoF250
I don't remember having to remove a plate, perhaps your year is different. Regardless, I would not use a pump, it would be very difficult to get the hose to the bottom and I would not trust it to get all the junk out.
RenoF250 is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 04:43 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Gear boxes have drains. Diffs need the covers removed to be sure you get all the crap out. Be very sure you use the correct gear oil for the gear boxes. GL4 or synchromesh fluid. Nothing that even hints at GL5 on the label works.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 06:17 AM   #4
JeepHammer
Running On Empty...
1973 CJ5
Mike Romain is correct, I have yet to see a gearbox without a drain plug...
JeepHammer is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 07:57 PM   #5
Unretarded
Unretarded's Avatar
1963 CJ5
Usually a pipe plug......usually same as the fill one.....might be a outy or a inny.......IE, it will have a square recessed or sticking out.
Jeep...the first vehicle on the moon.....next trip we are bringing the tub!
It is gunna cost more and take longer than you thought...plan ahead!
Unretarded is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 08:37 PM   #6
RenoF250
You can use GL5 in the transfer case. No yellow metal in there.
Unread 07-20-2014, 09:00 PM   #7
FLynes
FLynes's Avatar
1976 CJ5
Don't the transmission and transfer case share the same fluid in some models?
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
Grammar Test
FLynes is offline   Reply With Quote Quick reply to this message
Unread 07-20-2014, 11:43 PM   #8
Unretarded
Unretarded's Avatar
1963 CJ5
I just got a FSM and it states some models do....but does not specify which ones......I would treat all as they did share.
Unless you have had it apart to know for sure....or did some sort of pressure test to see if air makes it thru to the other side.........the way the manual states "some models" leads me to believe it is going to be hard to tell which ones do or do not......share.
Unread 07-21-2014, 04:35 AM   #9
AZ_Chip
AZ_Chip's Avatar
1978 CJ7
Guess I need better eyes or more light.
Unread 07-21-2014, 06:22 AM   #10
Mike Romain
Post a couple photos and we can likely spot them for you.
Mike
Unread 07-21-2014, 06:31 AM   #11
gmakra
If your talking about the Dana 300 it takes an Alan Wrench on the low point of the case.
The trans and transfer case are two different entities and drain and fill are separate for each one.
gmakra is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 06:40 AM   #12
Requiem4aCJ
If you're talking about the transmission in the jeep in your profile, an automatics isn't usually called a gearbox and yes you need to drop the pan to change the fluid and filter
Requiem4aCJ is online now   Reply With Quote Quick reply to this message
Unread 07-21-2014, 06:47 AM   #13
Mike Romain
I use a phone app to view the group which does not show profiles or SIG lines. It would be real helpful to you if you posted the details of your Jeep. As mentioned an automatic is not normally called a gear box. Slush box maybe, but not gear box.
Mike
Unread 07-21-2014, 08:12 AM   #14
CSP
Transmission or transfer case to be specific.
Anything with gears in it could be called a gearbox.
CSP is offline   Reply With Quote Quick reply to this message
Unread 07-21-2014, 01:26 PM   #15
AZ_Chip
AZ_Chip's Avatar
1978 CJ7
CJ7
AMC 360
TH400 Trans
Dana 30 front
AMC 20 Rear/ Moser one piece axle
Detroit Locker Rear
Dana 20 Transfer case
Automatic tranny is already done. I did that last week. I was looking at the gearboxes, Front diff, rear diff, and transfer case and only located the rear fill plugs. I have seen some with only a plug mid way up the case. If the drain plug is flush, like a square drive flush plug I have not located that yet on any of them. Also new to me is the vent line or the line on the front diff. Have not seen that before. Someone mentioned GL-4. Is that the same as what is specified in the Jeep manual, 75-90W?
Thanks for the help guys. A lot of learning going on.
