Gear Setup - JeepForum.com
post #1 of 5 Old 03-12-2010, 10:47 AM Thread Starter
shortgoroper
1983 CJ7
Gear Setup
Before I slap all of the axles back together. I am wondering how my CJ will roll down the road with a 232, T5 trans, AMC 20 with 2.72 gears??
I wanted to run 30" tires on it???
The jeep will be a daily driver on the highway, with some occasional off-roading (mild)
Thanks
shortgoroper is offline
post #2 of 5 Old 03-12-2010, 11:00 AM
desertrunner1
Well, being that I have a jeepspeed racer xj.. No not the ones that kids put a nerf bar and larger tires on and call it a jeepspeed.
Mine is SCORE and BITD approved.. Gearing is so important. In my opinion, I would get your gears to 3:73 or 4:10. You want to run 30's and at some point if you get larger tires, it will help.
I am running 33x10.50. Had 4:56 but finally went to 5:13 and feels fantastic. But again, mine is built for racing.
Good luck.
desertrunner1 is offline
post #3 of 5 Old 03-12-2010, 11:30 AM
CSP
Rather than guessing or letting other people guess for you, plug your information into the below link and determine what your engine RPMs will be at a given speed and determine if that will work for you.
Gear Ratio Calculator
For mostly highway driving the 30" tires and 2.73s will probably work well. You may not be able to use fifth gear on inclines, but it isn't a terrible combination.
Racing is quite different and so is the torque curve of the 232 vs. the 4.0 found in an XJ.
CSP is offline
post #4 of 5 Old 03-12-2010, 11:59 AM Thread Starter
shortgoroper
1983 CJ7
That calculator works nice. Thanks. I will give it a go.. If I am not satified.. I will do a gear change.
Thanks
matt
post #5 of 5 Old 03-29-2010, 09:13 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
With a T-5 and that tire size, the motor will be more comfortable in the 3.31-3.54 range.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
Gear Questions from a Gear Noob jeepsarecool Jeep CJ Forum 5 02-26-2010 06:56 AM
Dana 44 Question for Gear Setup Guys foggybottombob Jeep CJ Forum 9 10-18-2009 04:57 PM
What do you think the setup on the CJ is? hizza Jeep CJ Forum 16 03-06-2009 11:09 AM
85' CJ7 setup?'s skazaphava Jeep CJ Forum 0 01-14-2008 12:06 PM
Speedometer gear after gear change rcsutton Jeep CJ Forum 9 01-26-2005 01:32 PM
