gear ratio search - JeepForum.com
post #1 of 4 Old 02-05-2002, 01:45 AM Thread Starter
jeepster18_88
Post gear ratio search
Does anyone know how I can find the gear ratio in my '85 CJ7 w 4.2 & A/C without tearing into my differentials? What was your stock gear ratios? Thanks.
Josh
jeepster18_88 is offline
post #2 of 4 Old 02-05-2002, 10:09 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
Clean up the grease on the axle housing and look for the code (assuming none has swaped them):
http://www.jeeptech.com/axle/amc20.html
Also, you can jack up one rear wheel, and do that thingy where you rotate the tire once, and se how many time the driveshaft turns. If its less than 3, its likely 2.73, if its a little over 3, it 3.31, 3 1/2 times, 3.54, and so on . . .
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 4 Old 02-13-2002, 08:13 PM Thread Starter
jeepster18_88
Post
I've been told by many people that I could find approximately the gear ratio by jacking up the rear end, marking the tire and driveshaft, turning the tire one full turn while counting the driveshaft revolutions. It makes perfect sense and I tried it, but I only had one side jacked up. The ratio appears to be about 1.3 to 1.
What I'm saying is for 1 full turn of the tire, the driveshaft turns about 1 and a third times. I know that there was no such ratio made for the AMC 20 but that is the results. Could me not jacking up the other side have anything to do with the screwed up results. Thanks.
Josh
post #4 of 4 Old 02-17-2002, 04:40 PM
diamatron
1978 CJ7
Post
I am having the same thing haoppen here. I assumed with the 1.3 ratio only truning the one wheel doubling it woudl make 2.6. Guessing I have the dreaded 2.73 axles.
I will upgrade in the future.
"Use up what ya got, then buy what ya want"!
diamatron is offline
How to tell gear ratio GO-NOLES84 Jeep CJ Forum 4 10-24-2008 10:32 AM
Gear Ratio DeltaSigCJ5 Jeep CJ Forum 20 09-20-2007 12:20 PM
What gear ratio?? Fish4it Jeep CJ Forum 3 07-05-2007 07:14 PM
Gear ratio ROG97 Jeep CJ Forum 3 07-02-2007 11:31 AM
GEAR ratio petey156 Jeep CJ Forum 6 01-22-2006 01:19 PM
