Gear ratio ID - JeepForum.com
post #1 of 23 Old 02-25-2010, 01:17 PM Thread Starter
Gallbladder
1982 CJ7
Gear ratio ID
I have a ? year CJ that has an AMC 20 differential. The stamped number is supposed to be on the left side of the diff case by the cover. There is nothing there, but on the front of the rear diff at the top there is an "N" stamped on it. Is this the gear ratio Id? Thanks
Gallbladder is offline
post #2 of 23 Old 02-25-2010, 01:27 PM
Fatman
Fatman's Avatar
2008 CJ7
It's stamped on the ring gear behind the cover !
Thread Links:
Fatman is offline
post #3 of 23 Old 02-25-2010, 01:34 PM Thread Starter
Gallbladder
1982 CJ7
Gear Ratio
I wasn't wanting to take the cover to ID. What does the large "N" mean on the front top side of the rear diff?
post #4 of 23 Old 02-25-2010, 01:42 PM
Fatman
Fatman's Avatar
2008 CJ7
You don't know the year of the CJ, so certainly you don't know when the fluid was last changed. Good time to flush. While you're at it, take a look at the gearing.
Nothing.
Thread Links:
Fatman is offline
post #5 of 23 Old 02-25-2010, 01:45 PM
JoonHoss
2011 JK Wrangler
sorry to (sort of) disagree with Fatman, but an N stamped to the left side of a NT rear diff (like you should have in your '81) indicates it came with a 3.54 R&P with a trac-lok (from the factory)
if it is in fact, on top, then it stands for Nothing
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #6 of 23 Old 02-25-2010, 01:46 PM Thread Starter
Gallbladder
1982 CJ7
Good thought, thanks
post #7 of 23 Old 02-25-2010, 01:49 PM Thread Starter
Gallbladder
1982 CJ7
Jon hoss, the "N" isn't on the passenger side. It is in the middle of the pumpkin on the shaft side at the top.
post #8 of 23 Old 02-25-2010, 01:54 PM
JoonHoss
2011 JK Wrangler
who the HELL is jon???
hopefully, your axle has a shaft on each side
ok , seriously, on the flat boss where your axle tube slides into the diff housing on the left hand side, if you scrape away the crud, there should be a 1-2 letter code for what your Jeep came with from the factory.
What Fatman is trying to tell you is that the code won't mean squat if the gears have been changed, and that this is a good reason to service your Diffs
Hoss
post #9 of 23 Old 02-25-2010, 01:57 PM
Fatman
Fatman's Avatar
2008 CJ7
Hoss
Don't argue with me "John" I think he was refering to the big AZZ "N" on top.
Go back to your corner.
Thread Links:
Fatman is offline
post #10 of 23 Old 02-25-2010, 01:57 PM Thread Starter
Gallbladder
1982 CJ7
sorry joonhoos, thanks
post #11 of 23 Old 02-25-2010, 02:07 PM
JoonHoss
2011 JK Wrangler
YouTube - Fat *** jokes
Hoss
post #12 of 23 Old 02-25-2010, 02:20 PM
Fatman
Fatman's Avatar
2008 CJ7
Awesome !
Thread Links:
Fatman is offline
post #13 of 23 Old 02-25-2010, 02:50 PM
Daves77CJ7
1977 CJ7
OK. I am still a little confused. I have already powerwashed and degreased my rear axle. I will pop the cover off and ID my gear ratio that way in a couple weeks. Is there a stamp on the outside that will ID my gear ratio? I have a 77 with stock gears. Never changed. I see some numbers in different places, but they look greek to me.
Daves77CJ7 is offline
post #14 of 23 Old 02-25-2010, 03:00 PM
JoonHoss
2011 JK Wrangler
Originally Posted by Daves77CJ7 View Post
OK. I am still a little confused. .. Is there a stamp on the outside that will ID my gear ratio? I have a 77 with stock gears. Never changed. I see some numbers in different places, but they look greek to me.
Jeep Axle: AMC 20
Hoss
post #15 of 23 Old 02-25-2010, 06:49 PM
Daves77CJ7
1977 CJ7
OK. I think I found what looks like an "A" with a circle around it near the top of the rear axle. I also found a tag on the front of my front axle differential that has some numbers that look like 3 54 ......
Based on the link that Hoss posted above, an "A" stamped on the rear would indicate the same as the numbers on the tag of my front axle. Looks to me like I have 3:54 ratio.?? All this time, I had assumed that my 77 was a 3:73.
Is 3:54 a good thing or bad? I will be running 33's with my T18 behind my slightly built up 258 (bored .40 over, Offy intake, Holley 4bbl, and Headers). What do you guys think of this combination?
AMC 20 Gear Ratio? EtownCJ5 Jeep CJ Forum 17 03-26-2008 09:31 AM
What gear ratio?? Fish4it Jeep CJ Forum 3 07-05-2007 06:14 PM
Gear ratio ROG97 Jeep CJ Forum 3 07-02-2007 10:31 AM
Gear Ratio jrylb73 Jeep CJ Forum 7 02-26-2007 08:33 AM
Gear Ratio Mike78cj7 Jeep CJ Forum 12 02-22-2007 05:34 AM
