Gear ratio calculators vs. real life - Page 3 - JeepForum.com
post #31 of 32 Old 09-14-2013, 11:48 AM Thread Starter
fourbtgait
1930 MK Patriot
Thank you Keith for your input. I apologize if my synopsis of your gears/transmissions was a bit off, it is a bit difficult remembering and separating hundreds of posts in ones mind.
Do you feel then that the numbers on a gear calculator are fairly true and consistant from your experience?
And that 4.10, T5 and a 30.75" tire may be pushing it a bit? Though comparing your set up vs. mine on the calculator shows my 30.75 tire turning 100 rpm+ than yours.
Russell
fourbtgait is offline
post #32 of 32 Old 09-15-2013, 07:23 AM
keith460
Jeep. There's Only One
keith460's Avatar
I can't vouch for the gear calculator unless I'm looking at one but yesterday I had my CJ-7 out, and although it was getting dark, I could see that my rpm @ 60mph in 4th was 2500rpm. Shifted into 5th and that dropped the rpm down to 1900rpm @ 60mph.
Weight of the Jeep, tire diameter and the amount of air that is in them will also be a factor.
1984 CJ-7 Renegade
keith460 is offline
