gear question - JeepForum.com
post #1 of 5 Old 05-16-2013, 09:40 AM Thread Starter
clmelt1
1978 CJ5
gear question
I have a1978 cj5 with a 304, and I'm running 33" tires with no plans of going bigger. I'm in the middle of doing the yj spring conversion and i bought axles out of 2 different cj7's. The rear is a dana 44 the last numbers on the gear are 43-14, I'm assuming that means its 3.30 gears, the front is a model 30 with gears marked 43-13, so that's 3.07 gears right? Can i run these together or do i need to regear one of them? If so which one should i regear to match the other one? Thanks
clmelt1 is offline
post #2 of 5 Old 05-16-2013, 09:57 AM
jeepwhore
Yes, they need to match. I personally would want at least 3.73 but given the choice I'd match the front to the rear and run the 3.31's.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #3 of 5 Old 05-16-2013, 10:12 AM Thread Starter
clmelt1
1978 CJ5
Thanks for the advice, I would like to change both gears eventually, but i can only afford to do one axle now, I just want to get them under the jeep and get back on the road
clmelt1 is offline
post #4 of 5 Old 05-16-2013, 10:40 AM
CSP
If you can keep it out of 4wd while you get to that 'eventually' for both axles you can still drive it. Regearing isn't cheap.
CSP is offline
post #5 of 5 Old 05-16-2013, 11:49 AM Thread Starter
clmelt1
1978 CJ5
I don't think i could keep it out of 4wd, I have a couple trips planned already. Maybe I'll just leave the stock axles in it for now. Was going to put the widetracks in while everything is apart.
clmelt1 is offline
