Gear change with 33" 12.5's?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Gear change with 33" 12.5's??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePANDEMIC-USA 50" Double row LED LIGHT BAR!! These thi50" SINGLE ROW PANDEMIC LED Light bar FEATURES 4D Opt
Unread 06-26-2002, 10:48 PM   #1
jeeperzcreeperz
Post Gear change with 33" 12.5's??
Should I change my gearing with 33 12.5's? The jeep now has 31's I believe and was running on them for quite a while. Thanks.
75 CJ5 In process of restoration.
Metalic blue, Dana 44 Dana 30, 33 12.5 15 on 589's. Ford T18 4 speed, Dana 20 case. Upgraded to AMC 258 with Howell fuel injection, 4 ponit cage.
jeeperzcreeperz is offline   Reply With Quote Quick reply to this message
Unread 06-27-2002, 02:19 AM   #2
cj7traildriver
Post
That deppends on you really. I dont know what you have for gears now or motor. But if out of your power band now or close will be more with the 33's. 4.10 gears would be good with 33's or 4.56 if you dont do much high speed driveing would have a high rpm.
Jeep what else matters.
cj7traildriver is offline   Reply With Quote Quick reply to this message
Unread 06-27-2002, 05:16 AM   #3
Liberty-4-All
Post
Check out this site:
<a href="http://www.4wheelparts.com/Tirel_Gear_Ratio.asp" target="_blank">Gear Chart</a>
02 Sahara Edition KJ
Best Mod...PowerTrax No Slip Locker
265/75/16 Maxxis Buckshot Mudders
ARMOR, ARMOR, ARMOR
LLL=15.75"
L.O.S.T.member #000001
Visit www.KJJeep.com
I got your Grocery Getter Hangin'
Liberty-4-All is offline   Reply With Quote Quick reply to this message
Unread 06-27-2002, 08:15 AM   #4
MR.CJ-7
Post
4.56 here and no probs even with my 3 spd auto. 3500 rpm @65-70
Former CJ'er
MR.CJ-7 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2002, 10:30 AM   #5
jeeperzcreeperz
Post
Thanks guys, Do any of you know what stock gears are in a 75 CJ5? Also, did LSD's come stock in older Jeeps? Thanks again.
Unread 06-27-2002, 04:19 PM   #6
MR.CJ-7
Post
My stock setup was 3.54 with a LS in the 20.
Former CJ'er
Unread 06-27-2002, 10:51 PM   #7
BillR
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by MR.CJ-7:
<strong>4.56 here and no probs even with my 3 spd auto. 3500 rpm @65-70</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I feel better now. I run about 3200 at 65 mph with my 4:11s. Is this not a lot? It sounds high to me.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline   Reply With Quote Quick reply to this message
Unread 06-27-2002, 10:52 PM   #8
80cj
80cj's Avatar
1980 CJ5
Post
Stock gears in a 75 CJ-5 are 3.73 with 4.27 being optional.
80cj is offline   Reply With Quote Quick reply to this message
Unread 06-28-2002, 07:39 AM   #9
MR.CJ-7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by BillR:
[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Arial">I didn't think it was too high, look at the stock ratio and the stock 27"? tires. I checked it out on a chart and it put the rpms at about 3200 stock. I am anticipating about 3200-3300 when I put my 35's on and that should be about stock. Before gearing to 4.56 I ran about 2400 on the freeway and had no power in reserve. Now I feel I am right in the powerband, as it has plenty left when I need to pass someone.
Just my $.02 though
Former CJ'er
Unread 06-28-2002, 08:57 AM   #10
BillR
Post
<strong> </font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by BillR:
</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">I didn't think it was too high, look at the stock ratio and the stock 27"? tires. I checked it out on a chart and it put the rpms at about 3200 stock. I am anticipating about 3200-3300 when I put my 35's on and that should be about stock. Before gearing to 4.56 I ran about 2400 on the freeway and had no power in reserve. Now I feel I am right in the powerband, as it has plenty left when I need to pass someone.
Just my $.02 though[/QB]</font><hr /></blockquote><font size="2" face="Verdana, Arial">I can definately pass easily! I've been putting off road trips due to not wanting to run that many RPMs for very long. I'm glad that it's not harmful!
