Gauge Wiring Temperature and Oil - JeepForum.com
post #1 of 7 Old 06-06-2013, 10:43 PM Thread Starter
AdnanBatman
1981 CJ7
i have a cj7 with a 92 4.0 liter engine out of a Cherokee.
i dont know how to hook up the gauge with the engine. i dont know if the switch is mechanical or electric, but the output for the engine is electric. its a sun pro brand, and came in the jeep when i purchased it. The guy i bought it from said i should wire it AFTER the fuze box, so where would i splice into the wire to hook up the gauge. according to the guy, it has been wired from the engine to the fuze box but i dont know if it is for sure. is there a way to test that? and how would i wire it after the fuze box?
thanks to all help!
AdnanBatman is offline
post #2 of 7 Old 06-07-2013, 02:16 AM
John Strenk
John Strenk's Avatar
1976 CJ5
i dont know how to hook up the gauge with the engine. i dont know if the switch is mechanical or electric, but the output for the engine is electric. its a sun pro brand, and came in the jeep when i purchased it. The guy i bought it from said i should wire it AFTER the fuze box, so where would i splice into the wire to hook up the gauge. according to the guy, it has been wired from the engine to the fuse box but i don't know if it is for sure. is there a way to test that? and how would i wire it after the fuze box?
thanks to all help!
Did the PO put the 4.0 into your jeep and the Sunpro gauge or did you put the 4.0 in and the jeep already had a Sunpro gauge installed?
To me it sounds as if the PO installed the Sunpro temperature gauge but did not finish the job. He already ran the wire from the sensor through the bulkhead connector to the gauge. The bulkhead connector is sometimes called the fuse box because they are attached to each other. He just never wired up the power which has to go to a fused circuit. preferably one that is switched off with the key.
I would splice it into the power wire to the Oil pressure gauge. That way all the gauges are on the same circuit.
The only way you can find out if the wire is installed through the bulkhead connector is to trace it out by hand or buy one of those network ringers that you attache a transmitter on one side and use a hand receiver to track down were it runs.
John Strenk is offline
post #3 of 7 Old 06-07-2013, 02:46 AM Thread Starter
AdnanBatman
1981 CJ7
No those gauges were hooked up to the original engine 2.5L. So he did the swap. I don't know if they would work with the 4.0 and if they would work, how?
post #4 of 7 Old 06-07-2013, 02:54 AM
John Strenk
1976 CJ5
So everything was working before and just need to hook it up to the 4.0.
The oil pressure would work if the threads match but you could always buy an adapter.
The temp may be a little more 'interesting' You need to find out were the original temp sensor screws into the 4.0
Then see if the Sunpro sensor screws into that hole.
Or see if the stock 4.0 sensor has the same resistance range as the Sunpro sensor.
post #5 of 7 Old 06-12-2013, 08:04 PM Thread Starter
AdnanBatman
1981 CJ7
How do i find the resistance range for the 4.0 sensor. Sorry I'm very new to the jeep life.
post #6 of 7 Old 06-12-2013, 11:21 PM
aggiejon
1979 CJ7
Temp sender on the 4.0 is in the thermostat housing.
aggiejon is offline
post #7 of 7 Old 06-13-2013, 12:43 AM
BagusJeep
1981 CJ7
I just look up stuff like this on Jeepforum using the Search facility. Straight from the Cherokee forum:
212 farenheit 185 ohms
160 farenheit 450 ohms
100 farenheit 1600 ohms
70 farenheit 3400 ohms
40 farenheit 7500 ohms
20 farenheit 13,500 ohms
0 farenheit 25,000 ohms
-40 farenheit 100,700 ohms
It was cheap and quick but probably wrong, goodness knows where all this data comes from on Jeepforum.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
