gauge trouble - JeepForum.com
post #1 of 7 Old 02-03-2002, 10:20 PM Thread Starter
jeepster18_88
Post gauge trouble
I have an '85 CJ7 with a 4.2L. The gauges aren't reading right and I don't have very experience with electrical trouble. The temp gauge reads almost all the way on hot before cranking even in cold weather. The fuel gauge reads a little less than half when it is full. The voltage gauge reads pegged out when engine is running and just above 14 when it not. The oil pressure gauge reads above 0 before starting and a little above 20 when idling. It seems to me that all the gauges are off. Does anyone have any suggestions on what might be causing this? What would be the cheapest route in fixing the problem? Could it be caused by a bad voltage regulator? Are there any sites that show or tell how to test and fix the problems I'm having? Any help would be greatly appreciated. Thanks.
Josh
jeepster18_88 is offline
post #2 of 7 Old 02-04-2002, 09:23 AM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
Cool
You mkay be right about the volatage regulator.
Most good manuals, like Haynes and Chilton, even the Jeep Bible, have specs for the resitance for each gauge. You will have to use an elecrical multi purpose thingy to read the ohms for each, after you disconnect each gauge. There may even be a way to test the voltage regulator, but I've never looked into that.
While I too am an electrical idiot, this is really not that hard to do. Good luck.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 7 Old 02-04-2002, 09:46 AM
Nicks_Little_CJ_Tank
Post
Ditto to CJeep on the one. Like my other reply, I would recommend consulting the Haynes manual before anything else. It shouldn't be too hard, and a lot cheaper than taking it to an 'honest' mechanic, if one exists .
Nick
1984 CJ7 Undergoing Engine Rebuild
"The Little CJ Tank"
Nicks_Little_CJ_Tank is offline
post #4 of 7 Old 02-04-2002, 02:28 PM
JIM79CJ7
JIM79CJ7's Avatar
Post
This will answer all your questions and then some ! gauge info !
Goodluck , JIM
originally posted by Mikeythefireman :
Mr. Bill, you're a Jacka$$! or should I say 'drack you're a Jacka$$ I was looking for a straight answer there.
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
1979 CJ7 / 304 /T 150 /HUGGER ORANGE PAINT JOB/ Lots of cool stuff
2003 Inca Gold Rubicon , <------ Sissy jeep :)
JIM79CJ7 is offline
post #5 of 7 Old 02-04-2002, 02:33 PM
JIM79CJ7
JIM79CJ7's Avatar
Post
Sorry about that , TRy this ! null jim
Custom Stuff---
ORANGE JEEP CLUB
MEMBER # 1
JIM79CJ7 is offline
post #6 of 7 Old 02-04-2002, 08:56 PM Thread Starter
jeepster18_88
Post
Thanks for all the help. I'm not so sure about the Haynes manual though. One came with the CJ and I'm about ready to burn it. It good for some things but it's no help on fixing the things the previous owner screwed up trying to fix. I'll keep it anyway 'cause it still knows more than I do. Thanks again.
Josh
post #7 of 7 Old 02-06-2002, 02:34 AM
Guy Hollister
Cool
That link is certainly informative,.... but the one theing it assumes is there is a big problem... as did I when I had this exact same problem...
The temp gauge was sky high... i didn't have a clue so i called a mate... he said uh oh ... your thermostat is blocked or dead... remove and check it ... so i, being the obedient idiot that i am did this... guess what it tested fine in my kettle and now all my coffee tastes of CJ blood - [but thats good]... then i replaced it... then he said uh oh... that means it might be your water pump could be buggered ... but i dont know - good luck - bye....!
I shook my fist...
I called a jeep mechanic... he said "seen it a 1,000 times"... and is it both fuel and temp or just temp ? I said ahhhh haaa he knows something... just temp i said... he said remove the temp push on connector at the back of the gauge... its 5 cm's up from the bottom of the dash... wait and then turn on the ingition... then replace it.
I did.... it reset the gauge.... and the problem was fixed.
All it was is the contact between the connector and my gauge post was not perfect. Don't go all crazy with volt meters and screwdrivers before you do that... and if its both gauges then remove both wires... but the are in serial so the temp removal will effect the fuel reading as well.
Good luck.
Experience is the best way to learn - and always ask more than one mate before removing a thermostat or anything else for that matter.
Guy
Kung Fu.
1984 RHD CJ7
1979 LHD CJ5
Guy Hollister is offline
Temp gauge and fuel gauge quit Foulplay Jeep CJ Forum 11 11-09-2012 10:43 AM
I Got My Fuel Gauge Working by Putting Stock Oil Gauge Back In Pog Jeep CJ Forum 4 11-09-2011 01:01 PM
TEMP GAUGE, FUEL GAUGE, AND SPEEDO HELP PlEASE cgi2099 Jeep CJ Forum 8 11-03-2009 06:49 PM
Vacuum gauge Trouble lascelet Jeep CJ Forum 7 07-28-2008 10:13 AM
Speedo, Fuel Gauge and Temp gauge not working KYCJ7 Jeep CJ Forum 1 07-07-2008 01:41 PM
