Gauge hookup - JeepForum.com
post #1 of 8 Old 02-16-2008, 12:17 AM Thread Starter
kstopp
1993 XJ Cherokee
Gauge hookup
I'm not quite sure where some hookups for the gauges are for my 304. I'm hooking up an electric oil pressure gauge and an electric water temp gauge. Where do the sender units go into the engine? Also does anyone have pics of dashes where they located gauges. I was thinking two more ontop of the two holes that are on the dash (fuel and volts).
kstopp is offline
post #2 of 8 Old 02-16-2008, 01:38 AM
flashawk
flashawk's Avatar
1979 CJ5
Oil pressure sending unit is down next to the oil filter, the temp sending unit is right below you're distributor cap.
Right above you’re stereo cutout are 2 holes, those are for the oil pressure and the volt meter
flashawk is offline
post #3 of 8 Old 02-16-2008, 03:43 AM
bluwtrsurfr
bluwtrsurfr's Avatar
i am redoing the dash in my 81 Jeep, to include rewire some things. I went from the traditional big speedo with fuel and water temp built in to electronic gauges. If you are doing the same, you may need to wire up a ground and a lead 12V to the back of these gauges. I used the leads 12V from the other gauges so they would all be ACC. I am going to use where the radio cutout is to mount two of the 4 gauges I am putting in. I will cover the hole, then cut out the 2in holes. Pics to follow....
Will
81 Jeep CJ5 4" lift, 33" Mickey Thompson Baja Claw tires.
bluwtrsurfr is offline
post #4 of 8 Old 02-16-2008, 12:02 PM Thread Starter
kstopp
1993 XJ Cherokee
Thanks for the locations! Has anyone run into problems where a head unit has bend the stock dash. There are no support brackets for the radio that was installed in my jeep. The radio was just clicked into the dash and hung off it.
kstopp is offline
post #5 of 8 Old 02-16-2008, 12:35 PM
Mike Romain
Most Stereos come with a strap for this that bolts on the end of the unit and up to something. You can use a product called 'all round', flexible strapping with holes.
Mike
Mike Romain is offline
post #6 of 8 Old 02-16-2008, 11:27 PM
Trapshooter
Plumbers tape will also work to support the back of the radio. Plumbers tape is a metal strip with holes that any hardware store will have.
Trapshooter is offline
post #7 of 8 Old 02-17-2008, 01:25 AM Thread Starter
kstopp
1993 XJ Cherokee
Anyone have pictures of their dashes setup with extra gauges than came stock?
kstopp is offline
post #8 of 8 Old 02-17-2008, 10:36 AM
Mike Romain
Up here in Canada, one brand is called 'All Round'.
Mike
Need pic of Dana 300 shifter hookup.. NWA_CJ7 Jeep CJ Forum 3 11-15-2012 09:40 PM
Fuel gauge hookup AMSting Jeep CJ Forum 1 06-13-2007 12:44 PM
Winch Hookup jamesa Jeep CJ Forum 9 11-10-2006 05:06 AM
distributor hookup KG4PAM Jeep CJ Forum 2 01-24-2003 01:31 AM
tach hookup KG4PAM Jeep CJ Forum 5 12-14-2002 10:02 PM
