Gaucho part II - Page 4 - JeepForum.com
post #46 of 166 Old 08-02-2010, 06:47 AM
skotsour
2011 JK Wrangler
I eagerly watched the auction wishing I had the extra cash to bid. I was hoping it would go to a JFer and we would be able to keep this beauty in the family and get to continue to watch it's progress! Congrats! I'm sure you will do a great job!
skotsour is offline
post #47 of 166 Old 08-02-2010, 10:16 AM
CJorDie
1980 CJ7
Don't know if anyone's mentioned it yet but personally I would go for the Cummins 4bt/NV4500/D300 combo. Worktruck all the way and the lengthened wheelbase will help with fitting that NV4500 in there!
CJorDie is offline
post #48 of 166 Old 08-02-2010, 03:14 PM Thread Starter
monte jeep
Nobody has mentioned it yet, but I have looked into this motor for my other Jeep. I think it is a cool swap, but I don't think its right for Gaucho.
monte jeep is offline
post #49 of 166 Old 08-02-2010, 03:45 PM
XJAbuzer
Hmmm....thats a thought....the drivetrain he listed with 1 ton axles and suspension and make it your tow rig....how cool would that be.
1979 CJ-5 304 V-8, T-150 3 speed, Dana 20, Dana 30 front, AMC 20 rear, Sold
Anyways, I wanna go wheelin'!
XJAbuzer is offline
post #50 of 166 Old 08-02-2010, 04:06 PM
JoonHoss
2011 JK Wrangler
unique? yes
cool? yes
good tow rig? nope
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #51 of 166 Old 08-02-2010, 05:35 PM
SeaWulf
1983 CJ7
I would go with a 360, T18? and D300 along with NT wagoneer axles for the drivetrain, but that's just my $.02
SeaWulf is offline
post #52 of 166 Old 08-02-2010, 09:39 PM
Mark4883
This would be a cool plan, I say go for it.
Mark4883 is offline
post #53 of 166 Old 08-03-2010, 02:13 AM
TJandMe
Why not give the Golen 4.6L I6 stroker engine a shot? You can get one that is a direct bolt on for a YJ so you can buy and stretch a YJ frame, pop this 260hp replacement engine in there, and not worry about all the conversion headaches that many of the other engines requested will require. And it stays very true to keeping it as close to "factory" as possible.
Golen Engine Service WRANGLER - GOLEN 4.6L / 260hp Long Block Drop-in Stroker Engine - Quadratec
If you are not buying local, at least buy American.
TJandMe is offline
post #54 of 166 Old 08-03-2010, 04:26 AM
jscherb
In addition to the stretch of the YJ frame you mention, some additional fabrication would be required to mount the Gaucho bed to the wider YJ frame. And a little bit of fab is typically required to get a CJ grille shell to mount properly on the YJ frame.
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #55 of 166 Old 08-03-2010, 07:44 AM
LBrook
good luck
LBrook is offline
post #56 of 166 Old 08-03-2010, 07:48 AM
MisterO
good luck with this one.. got my eye on it..
MisterO is offline
post #57 of 166 Old 08-03-2010, 08:54 AM Thread Starter
monte jeep
I took a look at the Golen 4.6. The motor is $3500 before tax and shipping as a long block, then I would have to buy all the brackets and parts individually or buy a donor motor. So in the end this option is in the $4000 range just for an engine. I could get an entire drivetrain for that price, or even a whole running donor vehicle. I'm not kicking the engine, but its a lot of money. I don't have endless funds, so I need a bit more price effective option.
I was planning to build a truck similar to this, but decided to buy the Gaucho because everything I don't do (welding/ fabrication/ bodywork) is pretty much done. I have thought about stretching a YJ frame, but I would need to have someone do it, which would be another expense in the build. So, for now, I'm keeping the frame Jeff built. I actually do have a YJ frame already from the collection of parts to build a pickup. If anyone is interested in the YJ frame, its for sale.
post #58 of 166 Old 08-03-2010, 10:13 AM
kickingprop
So options abound, here's what I consider the reasonably priced options to consider:
1) 258/T18 (or T176, or NV3550 if u want OD) and a Dana20/300.
Pros: Bolts right in, pretty easy to come by most parts
Cons: mostly older technology on the engine
Upgrade of choice: Fuel Injection, Ignition upgrades
2) 4.0L/NV3550 (or AW4)/Dana300
Pros: Large availability of parts, reliable, mostly a bolt in
Cons: Cant really think of any
Upgrade of choice: I dont know much about the 4.0L's so I'll leave this to someone else
3) 360(or 401)/T18/Dana20(300)
Pros: Great power, pretty easily sourced parts
Cons: Gas guzzling
4) SBC/SM465(or 700R4/TH350)/Dana300 (or NP20x)
Pros: Tons of Power, Tons of aftermarket, endless options
Cons: Guzzling fuel, potential MAW's problem...
Upgrade of choice: Ignition
5) 5.3L/4L60E/Dana300 (My personal choice but I might be biased)
Pros: Great Power, good fuel economy (I get 20+mpg highway), reliability, lots of aftermarket already, pretty easily sourced (I got my 2001 5.3/4L60E combo for 1050$ with computer) Surprisingly easy to set up with a little help from the people who have done it already.
Cons: slightly higher initial cost for adapters and auxiliaries
Upgrade of choice: None I can think of...maybe a turbo kit??
6) Other combos... (4bt, stroked I6, SBF's, etc)
As for axles. unless you plan to wheel the crap out of this thing or run huge tires. I'd rebuild the CJ axles with some one piece shafts and call it a day. At the most run Wagoneer D44's but I wouldnt go any wider than that. For a street queen/light work truck, those axles will be great behind any of those engine combos.
This is just my on the possible ways to do this. I'd personally like to see it stay as close to CJ as possible with the 258 setup but if you go SBC the Gen IV's cant be beat!
1985 CJ7 Project
Phase One : 5.3L Vortec/4L60E, Moser axles for AMC20, Twin Stick'd Dana300 - Completed
Phase Two: Bedliner, Rollcage, Seats, BESRK Rear Bumper w/ tire swing, Soft Top, and a few other goodies - Mostly Complete
Phase Three: Waggy 44 front, Scout D44 Rear, 4.56's, ARB's (F/R) SOA with YJ Springs, 35x12.50x15 BFG MT - Not Even Close to beginning
Also a mostly rust-free 1970 Scout 800A That I'll get to start working on someday...
Chrome won't get you home...BUT Rattle Can Black may just get you back"
kickingprop is offline
post #59 of 166 Old 08-03-2010, 11:03 AM Thread Starter
monte jeep
Cons: Gas guzzling
decisions decisions decisions. options 1 through 5 are all possible. I just don't know. If I stick with the stock axles with one piece shafts and gear change, are they strong enough for moderate wheeling and a v8. I don't think tires larger than 33's (maybe 35's) will fit in the rear wheel wells without cutting the fenders that Jeff made. I am not cutting them (don't worry Jeff), and besides, I think 33's are enough for the Gaucho.
post #60 of 166 Old 08-03-2010, 11:20 AM
kickingprop
I would think stock axles could easily handle 33's. Mine have held up OK behind my 5.3L on 33's now for over a year with no problems. Its all in how you drive it. I'm hoping you dont plan on beating this thing like it stole something from you!
1985 CJ7 Project
"Gaucho" CJ stepside pickup build jscherb Jeep CJ Forum 1449 11-15-2016 03:17 PM
Name of part and / or part number OldSkull Jeep CJ Forum 15 09-26-2009 09:37 AM
Other than Gaucho and Brute are there other Jeep Truck Concepts out there Smitm16 Jeep CJ Forum 12 09-23-2009 01:44 PM
ID A Part RetiredSERE Jeep CJ Forum 11 06-26-2009 06:00 AM
Need a Part Don't Know What It Is??? Jack-Jack Jeep CJ Forum 5 09-29-2005 09:20 PM
