gaskets & RTV on 304 edlbrk intake upgrade - Page 2 - JeepForum.com
post #16 of 18 Old 05-02-2010, 04:27 PM
Curt Reinhardt
1978 CJ5
Originally Posted by kmm View Post
Under installation #3 it says we advise eliminating end seals and use RTV instead? #5 reccomends a thin bead of RTV around water ports and intake?
Yep.....and it worked perfectly in my case.
Curt Reinhardt is offline
post #17 of 18 Old 05-02-2010, 10:22 PM Thread Starter
DeadPhish
1977 CJ7
I could not get the intake to "go on" when I tried to use the recommended edelbrock gasket with the valley pan gasket. It was to thick to get the bolt holes to line up on both sides so I had to remove the paper gasket and just go with the metal one. and why the hell edlebrocks tech line is only open m-f 7-6 is mystery most people I know who need to call for support have jobs during these hours.
"The inherent vice of capitalism is the uneven division of blessings, while the inherent virtue of socialism is the equal division of misery."
DeadPhish is offline
post #18 of 18 Old 05-03-2010, 02:36 AM
godfather901
1979 CJ5
Only use the valley pan, the dented circles around all the ports act as crush gaskets and thus why you should change it if you pop the intake off. The vp is used in place of just intake gaskets as they only seal the intake and supply no heat shielding or oil deflection. If you didn't seal some ports with rtv, it's no big deal as the crush zones will protect you. However if the intake works itself loose past the point where it's smashing those crush spots your going to have leaks. Personally I smeared gasgacinch all over the mating surfaces on both sides outside the crush zones and put rtv just along the outside of the ports and the front and rear seals.
1979 CJ5 304, 3spd USAF 32 Combat Comm "Anytime, Anywhere"
godfather901 is offline
Heater upgrade: What did you do with factory intake plenum? PortlandCJ76 Jeep CJ Forum 6 09-22-2013 02:54 PM
AMC 304 Carburetor/Intake Upgrade JonnysJeep Jeep CJ Forum 7 05-31-2013 12:37 PM
304 stock intake or upgrade to Edelbrock for Howell FI cfernandez Jeep CJ Forum 0 09-10-2008 03:36 PM
Intake Mani dbl gaskets nightstalker5.0 Jeep CJ Forum 3 02-24-2007 08:04 AM
need info on intake gaskets amc 360 rcgkaw Jeep CJ Forum 2 01-25-2007 11:19 AM
