Gasket or What Else? - JeepForum.com
post #1 of 8 Old 03-09-2007, 08:58 PM Thread Starter
Trac-Loc
So I am repacking my front hubs on my 85' CJ-7. I was wondering what people use to seal between the outer hub assembly and inner (brake rotor) hub assembly. When I took it apart, there was a thin layer of RTV silicone. And how much grease in the hub assembly when I repack it???
Trac-Loc is offline
post #2 of 8 Old 03-09-2007, 09:20 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
A light coat of silicone good for the seal..And inside the actual locking hub part is supposed to be a thin grease like white litium..Inside of the spindle hub I normally pack it as much as possible after packing the bearings..any other ?'s i got alot of pics from when i did mine..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
Originally Posted by Me
"offroad it, and wave then you might understand"
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..
Mr.Crowley is offline
post #3 of 8 Old 03-10-2007, 04:50 AM
Shameless Elmer
83 CJ5
1983 CJ5
Post a few please.
Shameless Elmer is offline
post #4 of 8 Old 03-10-2007, 09:30 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
pulling the rear seal
removing cone..same way inner and outer
using the old cone to drive in new one..setting the roter and hub in the wheel makes it much easier to work on..
packing the new beairing
I like to coat the inner cone with grease before I put in the bearing and seal
clean up the spindle,so the inner bearing slip on nicley..I put a lil grease on the spindle where the bearing sits so the bearing doesnt seize on to it like has happened on this one..
:hahaha: yj
post #5 of 8 Old 03-10-2007, 09:38 PM
Mr.Crowley
Mr.Crowley's Avatar
1980 CJ7
proper order of lock washers and spindle nuts
make sure after you tighten down the spindle nuts with the proper socket,use a drift to bend over the ear in te lock washer
hub innerds back together
putting a screwdriver in the rotor vent and wedging it in the caliper mount will help breaking the hub nuts free and tighning them
:hahaha: yj
post #6 of 8 Old 03-11-2007, 06:10 AM
Shameless Elmer
83 CJ5
1983 CJ5
Nice clear pics. Thanks
post #7 of 8 Old 03-11-2007, 06:34 AM
petey156
does anyone know where i can buy the axel nuts and retaining washers for a dana 30?
petey156 is offline
post #8 of 8 Old 03-11-2007, 08:44 AM
Redmanchew
Redmanchew's Avatar
1982 CJ7
JCW had a nice kit that had everything from the inner seal to the outer nuts.
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
AMC 20 Gasket shelldrake Jeep CJ Forum 14 07-23-2015 07:25 PM
orig gasket or gasket sealer on differential cover DeadPhish Jeep CJ Forum 2 03-01-2009 08:06 PM
Oil Pan Gasket Mike78cj7 Jeep CJ Forum 2 08-17-2008 05:58 PM
T-150 gasket help ReconRabbit Jeep CJ Forum 5 04-14-2008 05:18 AM
oil pan gasket for 258 lord_byron Jeep CJ Forum 2 05-10-2004 07:22 PM
