Gasket leak between intake and exhaust under carb. - JeepForum.com
post #1 of 3 Old 02-11-2009, 10:36 AM Thread Starter
Oakbluffjeeper
1977 CJ5
I had a gasket leak between intake and exhaust manifold where they are joined (under carb). The exhaust surface was flaking and not very flat. I tried to grind it flatter and put the gasket in and in two weeks it started leaking again.
Question, should I try again with 2 gaskets or a guy told me to use hi temp
gasket sealer without gasket or chuck manifold and go to header?
Oakbluffjeeper is offline
post #2 of 3 Old 02-11-2009, 11:15 AM
MikeMCJ
1951 M-38
I would try hi-temp permatex on both sides of the gasket. be sure to let it cure thoroughly before you fire it up. It won't make up for a huge gap, but the stuff works well.
MikeMCJ is offline
post #3 of 3 Old 01-23-2010, 11:42 AM Thread Starter
Oakbluffjeeper
1977 CJ5
thanks for the permatex tip, tried that and lasted about 20 miles. I found a 2 barrel intake and exhaust manifold on craigslist now i need 2 barrel carb
gasket between carb spacer and intake Jermy01 Jeep CJ Forum 4 04-22-2011 07:21 PM
intake and exhaust gasket question joes1982CJ Jeep CJ Forum 9 08-22-2009 08:51 AM
intake/exhaust manifold gasket ?? armedsks Jeep CJ Forum 1 05-24-2009 10:28 AM
Carb/ intake Gasket Questions HavaCJ Jeep CJ Forum 2 01-17-2008 12:59 AM
Carb intake leak? Fropleyqk Jeep CJ Forum 4 03-01-2007 02:49 PM
