gas tank lowering - JeepForum.com
post #1 of 5 Old 06-15-2002, 09:21 AM Thread Starter
double8
Post gas tank lowering
i need some help--i need to drop the skid pan under the gas tank on my 82 cj7 to get to bolts holding the rear bumper on .question--does the tank have straps also holding it up or does it just lay in the skid pan ? hope i dont have to deal with hoses etc just to get to these bolts.thanks double8
double8 is offline
post #2 of 5 Old 06-15-2002, 11:38 AM
NMullens
NMullens's Avatar
Post
The tank lies in the skid plate but is held on both sides by two straps. I know on mine, to lower the tank, I had to disconnect the filler and vent hose. What I did is just unbolt the bolts by the bumper leaving the other side of the skid plate bolted up and was able to drop the tank after disconnecting the two hoses.
Currently Jeepless - Previously owned 1983 SJ, 1979 CJ-7 and 1991 YJ
NMullens is offline
post #3 of 5 Old 06-15-2002, 11:45 AM
Cophgnsnuf
Post
My 82 must be all out of wack I had to drop it to put on the new shackles I took out the 9 or 10 bolts to the skid plate thinking that the thing had straps holding it up no luck on mine thank god I had a jack under there at the time cause the only thing holding up my tank was the skid plate and hoses.
82 CJ7 36" superswampers. SOA ,2 1/2 inch lift springs and a whole lot of dreams. My baby.
Cophgnsnuf is offline
post #4 of 5 Old 06-15-2002, 06:03 PM
Bulletproofcj7
Post
</font><blockquote><font size="1" face="Verdana, Arial">quote:</font><hr /><font size="2" face="Verdana, Arial">Originally posted by Cophgnsnuf:
<strong>My 82 must be all out of wack I had to drop it to put on the new shackles.</strong></font><hr /></blockquote><font size="2" face="Verdana, Arial">May have been easier to just unbolt the two bolts holding the spring perch to the frame to pull the shackles out.
1982 cj7. Frame off. shell valley kevlar body, stainless hinges, Bestop seats and supertop, KC titanium lights, Homemade swing out tire carrier with spare front wheel bearings/hub, Built 304,DUI,Edelbrock shorty headers with dual stainless 21/2 tubes into incynerator cans 21/4 dumped out the back,Edelbrock 600cfm, performer intake and cam, Borgeson lower column, Centerforce clutch, NV-4500, Dana 300 w/custom built twin stick, Homade 1/4" steel skid plate, 2.5 soft ride w/ 1" shackle lift, 33x12.5 mtr's. Stainless fuel and brake lines, Braided hoses. more...
Bulletproofcj7 is offline
post #5 of 5 Old 06-16-2002, 10:42 AM
Cophgnsnuf
Post
Bulletproof your right it should have been but even after soaking those in PB for several days before I took on that project I still could not get them to loosen
T-Case lowering kit MoC Jeep CJ Forum 17 11-06-2009 12:04 PM
Tank is full, fuel gauge reads Half tank!?! martyweir Jeep CJ Forum 10 09-25-2008 06:55 AM
T-case Lowering Kit BAH07 Jeep CJ Forum 1 08-06-2008 11:38 PM
Lowering My Cj kydave Jeep CJ Forum 5 02-28-2008 08:51 PM
lowering t-case cjryder Jeep CJ Forum 1 03-30-2004 07:00 AM
