Originally Posted by mike223
Does the tank attach to the skid plate via the strap and then bolt up to the frame as an assembly?
Exactly. The tank itself is not bolted to anything, merely held in place by the retaining strap.
To what does the rolled tube on the end of the strap attach?
If I understand you correctly, the T fitting on the non-threaded end of the strap is there to hold that end of the strap, the strap gets tightened to the skidplate using a bolt on the other end (the threaded end). It slides through the rectangle cutout in the front of the skidplate and the T fitting catches the strap, preventing it from going all the way through (otherwise, it wouldn't be much of a "retainer").
Not such a great pic, but maybe it will help:
