GAS TANK FILLER HOSE(RESTORED CJ W/YJ TUB - JeepForum.com
post #1 of 8 Old 02-16-2002, 09:34 PM Thread Starter
2cjs
2cjs's Avatar
Cool GAS TANK FILLER HOSE(RESTORED CJ W/YJ TUB
Here I go again,First of all I want to thank all of you for your comments and suggestions.Yes its true I restored my 83 cj7 and put a wrangler tub on my frame.Yes there was plenty of modifications,but now im down to the small stuff and im not gonna sweat it.I called around today to get gas filler hose prices,talk about overpriced.Has anyone been down this road.I need the lines going from the filler neck to the tank.(ANY SUGGESTIONS).Im thinking about turning my tank around to make the lines shorter because we all know the yjs filler neck is on the left side .By the way the tub is a 1989.I dont want hydraulic or water lines because of the vicious fluid.
83 cj-7 258c.i., 727auto, d300, d44 front, d60 rear
92'yj 4.3(roller) tbi chevy,700r4 ,soa, 35-12.50-15 maxxis bighorns
89'yj wife's jeep 4.2l stock ,2"bl ,31-10.50-15 bfg mud terrains
work smarter not harder
2cjs is offline
post #2 of 8 Old 02-16-2002, 10:03 PM
junger
Post
I too am putting on a YJ tub on my 1986 CJ7... but if I understand you correctly... why not use the gas neck and filler your CJ and just drill a hole on the passenger side?
junger is offline
post #3 of 8 Old 02-17-2002, 11:50 AM Thread Starter
2cjs
2cjs's Avatar
Cool
Yes junger Im using my cj gas filler neck.That is an idea (cutting the hole)that I thought about but I dont want to cut any holes in the tub if I dont have to.I think what Im going to do is buy the oem replacement hose and use my old hose and cut and coupling them together.Im not one to cut corners on anything I do.I have spent over six thousand already.thanks for the input junger
2cjs is offline
post #4 of 8 Old 02-17-2002, 11:55 AM Thread Starter
2cjs
2cjs's Avatar
Cool
By the way junger if you dont mind me askin how much did u pay for your tub?and what yearis it?I picked my tub up at a bone yard for 400.00.
2cjs is offline
post #5 of 8 Old 02-18-2002, 12:33 PM
junger
Post
Well... I got a great deal on mine since the drivers side rocker panel was bashed in. I got it for $150!! at my local junkyard. I think its a 89 or so. They didn't feel like trying to remove everything, so they gave me the rollbar, pedals, and heater housing as well. I've already fitted my CJ tailgate and moved my body mounts on my frame. I'm going to buy some rear panel guards from warrior (the cheap ones) or some from off your rockers to relocate the gas filler. Basically, remove all all the corner metal and bolt on the new corners... I always try to stick with the KISS principle. I'm trying to decide whether to run a hydraulic clutch or not. Are you running linkage or hydraulic?
-Josh
junger is offline
post #6 of 8 Old 02-18-2002, 12:39 PM Thread Starter
2cjs
2cjs's Avatar
Cool
I went with hydraulic.Be sure if u go hydraulic to get the correct slave cylinder.Hydraulic I think is alot better than the linkage.By the way look at your firewall they didnt put the hole in it for the clutch rod (from pedal to linkage) How did you mount your tailgate?Im gonna do that to mine and mig my hinges to the tub instead of bolting.
2cjs is offline
post #7 of 8 Old 02-19-2002, 12:31 AM
Crash&Burn
Post
Just finished this part of my tub change-out this weekend, I cut the old corner of my CJ tub off and used it as a pattern on the new tub. Used tin snips to cut the new hole and all of my hoses fit perfect.
Will fill the YJ hole with a piece of metal an a little bondo. The license plate will mount in front of this area anyway.
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #8 of 8 Old 02-19-2002, 03:11 PM
junger
Post
The only problem with hydraulic, is that you can't replace it on the trail. You can always fix mechanical linkage.
Check out:
http://www.cise.ufl.edu/~junger/jeep/tailgate/
-Josh
junger is offline
CJ7 to YJ body Gas tank filler Hose CaptKK Jeep CJ Forum 0 09-08-2009 12:21 PM
1977 CJ7 Fuel Filler Hose and Vent Hose elybarnard Jeep CJ Forum 8 07-26-2009 09:29 AM
how to fix this fuel filler hose (see pic) DeadPhish Jeep CJ Forum 13 07-19-2009 05:32 PM
Gas tank and filler hose for a 77 CJ5 atom73 Jeep CJ Forum 4 04-05-2007 07:24 PM
Fuel filler hose 77 CJ5 atom73 Jeep CJ Forum 5 03-20-2007 01:17 PM
