gas tank and carb question - JeepForum.com
post #1 of 6 Old 05-03-2009, 10:07 AM Thread Starter
armedsks
2009 JK Wrangler
I have a webber carb on my cj. Im not getting 12 volts on my wire going to the choke. If its below 70 degrees, it takes a few cranks to get it to fire. Could i run a hot wire off my battery right to the carb??? Or could i run a hot off a wire to a toggle then to the carb?? Would i need to run a ground? The current hot wire appears to run into the firewall somewhere. (havnt looked behind the dash yet to trace.
Also when i dropped my gas tank to replace. I noticed my 2 little vent tubes (driverside) hose blocked off with a hose going to each. Shouldnt these be ran somewhere and left open to breathe?? I notice i have pressure when i open my fuel cap.
armedsks is offline
post #2 of 6 Old 05-03-2009, 10:22 AM
littlebuddie
1980 CJ7
You can always convert that Weber to a manual choke, I did and I like the control I have that way much better than the auto choke.
1980 CJ-7 258 Dana 300, SR-4 Trans, Basically Stock Except One Piece Rear Axles, Weber Carburetor.
O\lllll/O
[]=O=[]
littlebuddie is offline
post #3 of 6 Old 05-03-2009, 10:28 AM
Viencent
1982 CJ7
Ive been thinking about going with a manual choke, what does it take to make the switch?
Viencent is offline
post #4 of 6 Old 05-03-2009, 11:43 AM
littlebuddie
1980 CJ7
Cheap and easy. Lots of stores sell the universal kit for around $10 and it comes with complete instructions. Most kits come with a few sizes of replacement covers but I might suggest that you measure your existing choke cover so you are sure you get the kit that has the correct replacement. Google 'Choke Conversion Kit' to get an idea.
O\lllll/O
[]=O=[]
post #5 of 6 Old 05-03-2009, 01:59 PM
Mike Romain
Did you check your fuses? The backup light and seatbelt buzzer fuse I think runs the choke.
Mike
Mike Romain is offline
post #6 of 6 Old 05-03-2009, 04:39 PM Thread Starter
armedsks
2009 JK Wrangler
my back up lights work. Not sure about seat belt buzzer. Never herd a sound since i have owned it. Only fuse i found blown a was marked (dome-ctsy) its a 20A fuse. Need to buy some more. All fuses appear to be ok except for that one.
armedsks is offline
Carb question TKFireman Jeep CJ Forum 19 12-07-2009 11:21 AM
CJ-7 1982 Carb, Fuel Pump & Tank frank vandelden Jeep CJ Forum 0 09-25-2009 01:56 PM
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 08:29 PM
swapped fuel tank and no fuel at carb 8679cjs Jeep CJ Forum 6 12-05-2005 10:17 PM
question about 81 CJ7 carb jrod126 Jeep CJ Forum 1 07-28-2004 07:21 PM
