Gas tank - JeepForum.com
post #1 of 23 Old 01-02-2012, 07:41 PM Thread Starter
jamie0921
1973 CJ5
Gas tank
Filled up yesterday and woke up and if my gas gauge worked it would of said empty my tank is leaking from everywhere around sender around fill intake and between top and bottom halfs
jamie0921 is offline
post #2 of 23 Old 01-02-2012, 08:50 PM
Crazyray2929
1981 CJ7
WoW!
Go to the store and get ya a bag full of Bazooka Joe or a new tank.
Crazyray2929 is offline
post #3 of 23 Old 01-02-2012, 08:51 PM
85LaredoCJ7
Yeah.....I'm lost..
85LaredoCJ7 is offline
post #4 of 23 Old 01-02-2012, 09:17 PM Thread Starter
jamie0921
1973 CJ5
I just don't know what caused it it's never leaked before
post #5 of 23 Old 01-02-2012, 09:54 PM
Crazyray2929
1981 CJ7
Well you could drop your tank and JB Weld the seam..
Put some sealer around the sending unit top..
Maybe some new hose clamps or new hoses too...
post #6 of 23 Old 01-02-2012, 10:14 PM Thread Starter
jamie0921
1973 CJ5
thats where im heading jb weld
post #7 of 23 Old 01-03-2012, 07:38 AM
gunrun45
1982 CJ7
JB weld will not work. Do a search on patching leaking tanks, it's been covered many times before here. Do you have a plastic or metal tank?
gunrun45 is offline
post #8 of 23 Old 01-03-2012, 07:57 PM
spencerkemp
There is a product it's called all-seal its in a yellow tube I use it for trail fixes if it is under pressure use a little aluminum duct tape. Works great I had to do it to my tranny pan and fuel pump!
spencerkemp is offline
post #9 of 23 Old 01-03-2012, 09:34 PM Thread Starter
jamie0921
1973 CJ5
Metal tank
post #10 of 23 Old 01-03-2012, 10:44 PM
Hybrid Jeep
1976 CJ5
Hey Man.. I had a 1974 J10 and the exact same thing happened to it. One day it was like.. oh crap the fuel tank is leaking everywhere!! It turned out that the rubber fuel lines had cracked from age dumping fuel all over the tank. It gives the impression that it's leaking everywhere, but really it's just spraying out of those cracks in the hose.
I'd replace those first before you get too carried away with replacing the tank. While you have the tank dropped you can also give it a good look over. New replacement tanks aren't that expensive if you find problems.
Hybrid Jeep is offline
post #11 of 23 Old 01-04-2012, 12:36 AM
BagusJeep
1981 CJ7
If the tank has a problem they are fairly easy to drop and you will then have proper access to assess the condition of the tank and all those old rubber parts. It may indeed just be the rubber bits, they were not designed for 30 years use.
Fuel tanks are not that expensive so if it was leaking you may consider it easier to just buy a new one than try to patch a leaking one. The fix to a rare or expensive tank is usually to coat it internally and there are plenty of products on the market which can do it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #12 of 23 Old 01-04-2012, 12:58 AM
Captainak
1982 CJ7
Filler & vent tube .... Bout 20 bucks I had same issue
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
post #13 of 23 Old 01-04-2012, 12:02 PM Thread Starter
jamie0921
1973 CJ5
What kind of filler and I don't know what vent tube is
post #14 of 23 Old 01-04-2012, 12:04 PM
my_304_cj7
1976 CJ7
He is talking about the fuel filler and vent tube.
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #15 of 23 Old 01-04-2012, 12:18 PM Thread Starter
jamie0921
1973 CJ5
Lol I gotch now he he he
